Tein cs coilovers
EDFC helps you regulate the softness or the stiffness from inside the car.Not the height just softness and stiffness.I didn't order it because i will set the car where i want to and i want mess with it any more.Its good though for those who wants to stiff the car whenever they want to.
Believe me. EDFC will work very well and you will love it.
Sometime when you use in daily life and would like to drive fast on toll way, you just press the botton and EDFC will work for you. No need to lift your car for adjust.
Lift to adjust? You're kidding, right? EDFC surely doesn't lift the car, it just turns the **** at the top of the shock. No different than pulling over, popping the hood and tweaking it while sitting on the ground. It's just a remote controlled stepping motor on each shock. It's convenient. Nothing more.
Looking at the TEIN CS w/ EDFC and was curious, for those who have them, how soft can you make the ride? Meaning, I know you can stiffen the ride quite a bit, but how soft can you go...Will it actually go as soft or softer than the stock suspension?
The reason I ask is that when my wife and I take road trips I don't want her to complain that the ride is too harsh.
Thanks,
Charles
Thanks,
Charles
i got the tein cs in my Gs...Rides pretty smooth... but once on the freewAY or something if the road is messed up. i jus ajust the stiffness in my ride with the edfc.... if u have the money buy the EDFC ...if u dont then its still good coilover system... they only thing is that i cant slam it that low... i have it at a finger in the front and bacc...
