will 01 IS300 coilovers fit on 98 GS300?
Front: Top hat on IS300 bolts are closer and GS are wider. Lower bolt on IS300 is smaller compare to the GS.
Rear: fits without a problem.
If you run across SC430 coilover those will fit the GS. They just have a shorter shocks and a few hundred pounds heavier then the GS.
I have tried to test fit IS300 shocks and springs on the GS as I had a set laying around.
toolowbroo
Suspension and Brakes
02-08-10 08:32 PM
