Need help getting ball joints off
I need to get the ball joint off the knuckle on the rear suspension. It is the big ball joint that is connected to the control arm that is connected to the shock. I tried the autozone tie rod puller tools, one was too small the other didnt go on straight enough and it tracked off the bolt after a while, I actually broke the second pulled when I tried to use a blow torch to heat up the area. If I can use a pickle fork to get it off, what size do I need? Any other tools that could help get it off?
I've never actually had to use a fork. I always had good luck just backing up(supporting) the underside of the knuckle with a piece of steel rod or bar stock (wood will NOT work) onto a hard concrete slab below, and then just smack the top of the bolt sharply with a ball peen hammer a few times; just pops it right off when the force is all focused there on the ball joint.
Returd
Suspension and Brakes
12
09-12-17 06:04 PM
es30000000
12-04-12 07:56 PM
95gs300
GS - 1st Gen (1993-1997)
08-08-07 07:15 PM
