Need help with megan coilovers
I just installed my megan lp coilovers and im kinda confuse because i thought the front would go lower than this. I have the bottom part set to the lowest and did not even touch the upper part of the coilovers. my tires are 245/35/19 for the front. Can someone help me out. I want to go a lil lower.
![](http://i411.photobucket.com/albums/pp196/sn21983/DSCF4502.jpg)
the upper portion of the coil is not even touch out of the box. I only loosen the botton nut and turn the body tube tillits all the way down and then tighten the nut. I didn't mess with anything else cause i heard someone else said just to leave the other stuff alone.
