Driver Front suspension squeaking?
Do our bushing dry up & squeak. My driver front end is freaking squeaking like a *****. I tried spraying some liquid grease, which helped for like a week then it's squeaking again. I do have coils not sure if the drop had anything to do with it but damn, Getting annoying. I just cant tell exactly where its coming from. Any thoughts?
Tech Info Resource
Before lubing anything, I'd get underneath, loosen all the big bolts, load the suspension properly for neutral height, then re-tighten all the bolts with a proper torque wrench. In all likelihood, whomever did your suspension install did not do this properly so you have squeaking.
Ummm only install was coils & it was Tommy From Music Box whom has installed like half SoCal coils & what have you. The coils have been in Since Aug last year. The coils it's self isn't squeaking. Plus the squeak just started like a month ago so if were the install & after a Track day at Fontana, Big track at Willow Springs & 3 days at Chuckwalla. Pretty sure it would have squeaked way before that.
Tech Info Resource
OK. Bolts can come loose. Especially chassis bolts. I'd still do what I said first before spraying lube on anything.
Hah! If you're here in Boston you'll be blowing your brains out like I am. I've lost 3 nuts in my suspension in all different places over the life of the vehicle. Of course all I had to do was order and torque them right back up but yeah every now and then I get squeaking or clunking and I end up jacking up the car again just to fix it.
XSV
Suspension and Brakes
11-28-17 08:55 PM
