Control Arm Install Question (Rear Control Arms)
I am planning to remove and replace the rear control arms. However, there's one problem I need to figure out before I can start. The control arm bolts must be torqued down with the car's weight resting on the suspension (compressing the spring). If you torque the control arm bolts while the car is in a raised position (ie: using a jack) then you will destroy the control arm bushings.
The problem is when you have the car sitting completely on the ground how are you suppose to torque down the control arm bolts. I could see it being possible to torque down the lower control arm bolts, but the upper control arm bolts? I just dont see how to properly tighten these bolts up to avoid destroying the bushings. Hopefully I've explained this well enough and I really hope someone has the answer.
In the lexus repair manual it explains that once you have all the bolts finger tight your suppose to put the wheel(s) back on and bounce the vehicle up and down several times to stablize the suspension.
Then your suppose to jack it back up and remove the wheel and support the rear axle carrier with a jack and then torque everything down.
My question is do you torque the suspension bolts while the car is in a raised position such as on a rack or resting on the ground?
I thought you were suppose to torque the bolts down while the car is on the ground with its weight fully resting on the suspension evenly, so the geometry is correct between the control arms and the chassis.
To me it seems if you torque down the suspension while its on a rack "hanging" freely, its going to over extend the bushings when you put the car back on the ground causing premature failure. Which is the correct way?
To the best of my knowledge . . .
If the bushing are made of rubber that is attached/bonded/adhered to the inner sleeve, then you'll want them torqued in the normal operating position, NOT drooped!
If your bushing are NOT bonded to the inner sleeves, then yes, providing they are lubed, they should slip and adjust regardless of the attitude of the suspension when torqued.
The inner sleeve is what becomes immobile once torqued.
Does this apply to the front control arms as well? I changed out my lower front control arms and I didnt tighten them down when they were on the ground, but on the air....
Sampak
Suspension and Brakes
11-07-13 06:55 PM
