Unsprung vs. sprung weight
With a number of upgrades going with the increased weight of larger brakes (calipers and rotors) and wheel spacers, does it concern anyone about how harder it is to keep the rubber on the road with this extra weight momentum stressing the suspension?
If there is a discussion of this unsprung vs. sprung weight topic, please direct me to it.
Is there a discussion of wheel size/tire size to obtain the lowest possible weight while achieving performance with reliability?
It's kind of a give and take thing. Bigger brake calipers can reduce weight if made of a lighter material. Bigger rotors increase rotational inertia which could give more rolling resistance. Bigger wheels allow for shorter sidewalls for less deflection and roll and wider tread for more grip, but again create a larger mass moment of inertia (For a constant total wheel/tire weight) because the distance of equivalent mass concentration from the center of rotation is greater. If you get a wheel/tire combo that weighs less and has an equal or lower mass moment of inertia about the hub center than whatever set is currently on the car then you can have your cake and eat it too. Same goes for switching from steel to aluminum big brake calipers and lightweight rotors.
Bartledoo
Nice write up. That is a thorough explanation that included the effects of rotational inertia that I had overlooked. Now the next step is to find real world applications by CL'ers. What wheel size/ tire combos have worked on the SC? How have you reduced weight of calipers? This is tricky for safety reasons.
But calipers are not rotational weight ,yet its stil unsprung. So you are reducing the unsprung weight, yet increasing rotional with bigger rotors ,plus bigger wheels so........ummm bigger wheels need a bigger brakes ..........I think i just popped a vessel in my brain
Questions, questions,...
Bartledoo - need more info on your calipers.
Bigger wheels in most cases will be no lighter than stock and since the barrel and tire mass will be farther from center then yes, you will increase inertia. You could get a light enough wheel and tire package to combat that change though. Again you would need some advanced calculations to determine anything, and every wheel's weight distribution is different. I'd say 18's generally are the best choice for our cars performance wise. Anything more just seems to be for looks really and you certainly don't need any more brake clearance than 18's provide. You can't really say that bigger wheels need stronger brakes, though. It depends on other variables.
Lighter is always nicer, but you have to compensate for it. If you lighten up unsprung mass when the shock's compression valves are set for something much heavier, you can yield unwanted results.
Want a perfect match without having to do all the guess work? Put your car on a 7 post shake rig. Only catch is that it may cost more per hour than what the car is worth
When you're talking about unsprung mass, you're just talking about the mass, period. The larger rotors won't affect the suspension's performance if it weighed the same as stock. The rotational inertia matters more from an acceleration standpoint, which is a separate entity. If suspension performance is your main concern (seems like it is), concentrate on lowering the mass. If you have a 20lbs 15" wheel and an 18lb 17" wheel, the 17" will be more favorable for your suspension.
RacerLex
Wheels, Tires & Brakes Forum
03-17-07 08:39 AM
