Question on suspension/springs
I'm planning to re-install my oem springs. I had eibach springs installed when my car had 20k miles and it currently has 82k miles.
Are my shocks hindered from the lowering springs?
Should/Can I simply swap out the springs like I did previously with the installation of the lowering springs?
Thanks in advance!
Thanks in advance!
If you swapped out your springs and kept your shocks OEM, it may suffer some damage. It all depends on the spring rate of lowering springs. If you have a sports tuned shock (oem) then those shock should be able to handle the higher spring rate.
But if your shocks are the soft OEM ones for comfort, they are probably blown. You can check if there is shock oil leaking. Stock shocks can't compensate for the stiffer springs unless they are the sport ones to begin with.
Perhaps some experts can chime it. I just state what happen to my bro's Corolla when he dropped with TRD springs and kept his OEM shock. A year later, his shock was drooling shock oil and had to be replaced.
Thanks in advance!
Thanks in advance!
but generally springs will shorten the life of shocks.
They weren't leaking which is usually a good sign. Plus when shocks are blown, you can usually feel the bounce in the ride.
The oem shocks in my IS are not leaking; but since I messed with the springs I'm curious what the best option is for longevity/value.
Assuming the springs are Eibach 350',s then they are the same as F-Sport. No need to worry about the OEM shock life versus original springs.
And shocks at 287K have deteriorated, but since the deterioration happens gradually over time sometimes owners don't notice.
2. oem shocks can handle aftermarket springs. case in point, the f-sport springs are designed to work w/ the oem shocks, and everyone in here by now knows that the f-sport springs are rebadged eibach pro-kits. of course, the lifespan of the oem shocks will be shortened with aftermarket springs, although not at the high rate of detereoration some of us might be led to believe.
3. a massive amount of oil leaking is indication of a blown shock. however, a minute amount of oil residue on the outer surface of the shocks is not an indication of a blown shock. that, and you can usually tell from the degradation of ride comfort w/ blown shocks.
The wear happens over time so you're going to be immune to feeling any deterioration over 10 years, especially with stock springs. And not all cars will be bouncy when the shocks go out, especially with cars like the Accord where they're floaty from the factory. If that car with 287k miles were to have new shocks, I bet the difference would be very very apparent
rroy, if you're a DIY, you might as well reuse the OEM shocks and see how they work our for you. Worse comes worse, you'll have to get new shocks.
NVMYGS3
Wheels, Tires & Brakes Forum
03-29-02 08:58 AM
