Kw v3
What got on my nerve is labeling certain buyers brand wh0res because they didn't buy it for tracking. Does one need to track in order to appreciate KWs? That's like calling out Rolex owners brand wh0res when a Casio watch can tell time just as well.
^ Actually I would say yes, you probably do need to track your car in order to feel the difference. Like I said, I would bet you the vast, vast majority of people can't tell the difference between similarly spec'd coils once they're installed when daily driving.
And yes, if you're willing to spend tens and thousands of dollars on a watch, you're a brand wh0re. I'm not saying being a brand wh0re is some horrible thing either - I'm certainly guilty of it sometimes. But people should be honest about it.
^ I don't know what springs rates he used on his BCRs, the preload settings, the height, or how hard he drives (it is an F after all), so can't really speak for him. But for me, I haven't had any problems bottoming out or with noise though. Just the occasional rubbing. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Not trying to hate on KW's here guys. Like I said, I'm sure they're great coils. But the OP is talking about a minor drop and wanting a smooth ride. He might be better suited by Tein CSTs, since that's what they're designed for.
I've had the KW V3's installed for about a year with about a 1 1/2" drop. It's certainly not slammed by any means but I like the drop. Very nice ride... But you can play with the settings and pretty much set it up any way you like.
I have a very slight rub up front but only when pushing it hard around corners. I have the rebound set in the middle of the range. The roads are kinda bad where I drive. But I am thinking about adjusting the settings a little stiffer.
I have not used any other brand of coilovers. But I like the KW's a lot and have NO regrets about installing these.
Back to the the original topic: Stock4AG, since you're in CA, I bet you won't have a hard time tracking down someone with a set of coils. Get a few rides before you throw a large chunk of change on a set of coils. One thing I do know is that the KW cost only a bit more than the Tein CST with with good reasons. Hopefully you can find a shop that can tune the KWs if you do get them. If done right, they will give you a ride/performance that the Teins cannot give you.
What is wrong with paying more for quality? And no, you do not have to track in order to feel a difference. If you drive on roads that are some of the roughest, the difference comes into play. Generally the higher priced items (made for comfort) will have dampers that perform better while the springs are true linear, and not just advertised as one. Buying into a certain reputable brand isn't just a performance thing. Lifespan of a shock, consistency, etc will vary from one manufacture to another. The majority of the people on this site run K-Sport, Megans, BC, Powered by max, etc but they're also their first and only set of coilovers.
While you aren't implying brand wh0re as a horrible thing, it certainly is offending those who did pay more to get something extra. And what constitutes KW as a brand for brand wh0res? Because it is out of our own budget? BC costs considerably more than NEX coilovers (crap btw) and will do what most other coils will, but it's not lumped in the same bag as KW?
its not always the spring rate. VALVING has a huge roll in this. V3 is prolly the best out there and i can say that since i have tested all the brands out there for the ISF and for comfort and handling they work well. BUT i can say the BC is a great setup if valved and sprung right.
