-4 camber with front RCA..
Old 08-21-10, 01:09 PM
lunatyk
lunatyk's Avatar
Default -4 camber with front RCA..
I just put my coilovers in and sage front rca's. Went to get an alignment and the camber is still -4 with my rca's.. Is that correct? Is everyone with rca's lowered getting that much negative camber??
Old 08-21-10, 01:12 PM
GSteg
GSteg's Avatar
How much are you lowered? RCA do not really reduce camber, especially when you're dropped really low due to the way the UCA swings.
Old 08-21-10, 01:24 PM
lunatyk
lunatyk's Avatar
I'm lowered alot.. Don't know the amount but I'm about 2.5 inches from the ground. I thought rca's correct camber a little bit. I guess not. So looks like I'll need aftermarket uca's.
Old 08-21-10, 04:08 PM
GSteg
GSteg's Avatar
Aftermarket UCA may or may not help your situation as much as you want them to. Your upper control arm ball joints are already sitting at an angle that's less than desirable. Having the aftermarket UCA can help reduce negative camber, at the expense of having the ball joint sitting at an even more extreme angle. If you want to reduce camber without stressing out the upper joints as much, remove the RCA and get the adjustable UCA. The downside is the roll center gets worse and the lower ball joint is now angling even further. It's a give and take situation until someone comes up with a shorter knuckle and/or new lower control arms.
Old 08-21-10, 04:11 PM
lunatyk
lunatyk's Avatar
Oh wow. It's like a lose lose situation..
Old 08-21-10, 04:16 PM
GSteg
GSteg's Avatar
Being low isn't for the faint of heart
You're that low, it's already accepted that you're going to get a good amount of camber wear whether you're at -3.5 or -4 degrees.
I mean 2.5" off the ground is really low... Aren't you afraid of getting stuck on speed bumps? I've seen some that makes me want to make a U-turn and find an alternate route, and even I'm not that low
Old 08-21-10, 05:32 PM
lunatyk
lunatyk's Avatar
Haha it's okay. I've been stuck plenty of times on my old car. Makes it a challenge. I guess my camber will suffer because I'm not going any higher
Old 08-21-10, 05:58 PM
GS4_Fiend
GS4_Fiend's Avatar
You should start to save up for air if you like to be low seriously...
Old 08-21-10, 06:15 PM
VNN326
VNN326's Avatar
pictures of ride height plox
Old 08-21-10, 07:13 PM
vwynn
vwynn's Avatar
what if someone was to take OE steering knucles and just cut em shorter? would that work?
Old 08-21-10, 07:14 PM
lilsharky
lilsharky's Avatar
did you put in the positive inserts for the rca?
Old 08-21-10, 08:58 PM
chrispy
chrispy's Avatar
I'm at -4* with RCAs all around too. I wish someone would make shorter knuckles for our cars.
Old 08-21-10, 08:59 PM
vwynn
vwynn's Avatar
inserts are for the rear RCA. his problem is regarding his front camber
Old 08-21-10, 09:19 PM
lunatyk
lunatyk's Avatar
Oh thanks guys. Just making sure my car was messed up somehow haha.. This is the only picture I have right now..
Old 08-21-10, 11:23 PM
sam430
sam430's Avatar
Fig is working on it... I just got my Mega arms last week....nice baby blue powder coat
he's also working on the front too...can't wait for that. PSsss... the rear end links are available at group buy price. got a set.
Quick Reply: -4 camber with front RCA..
