LS400 BBK questions on ebay auction
Old 08-23-10, 02:35 PM
danthedj
danthedj's Avatar
Default LS400 BBK questions on ebay auction
I've been interested in looking into new brakes for a while. My GS400 brakes well and the pads are in great shape but i believe the rotors are warped. Under certain braking conditions the pedal shakes a bit, but the steering wheel doesnt usually shake noticeably.
Will the difference from stock GS brakes in good condition and an LS400 BBK be noticeable? I found the front rotors and calipers on ebay for around $150 HERE and was wondering if that was all that would be needed for the upgrade? Well, along with pads.
Also, how easy is it to install? im not very handy but im trying to become better working on cars. How much would it cost for a mechanic to install the calipers?
Thanks everyone!
Old 08-23-10, 03:19 PM
GSteg
GSteg's Avatar
We have plenty of threads on the LS400 swaps.
You need to get Roll center adapters or shave off part of the tie rod bolt.
You also need wheels that will clear the brakes so if you're on stock wheels, you'll need 15mm spacers.
Old 08-23-10, 09:10 PM
danthedj
danthedj's Avatar
thanks for the reply GSteg. Unfortunately you answered all the questions previously answered with the reading i did do of prior threads. I was asking about the specific kit i linked to on ebay. It seemed like it had a few different parts included, and i was wondering if i would need anything else besides what the person was selling. For example, shims, or different bolts or anything else.
thanks for your speedy reply though.
Old 08-23-10, 09:29 PM
GSteg
GSteg's Avatar
And the answer still remains the same
The 'kit' in the ebay link is no different than any other LS400 calipers out there. Those shims and guide pin are just taken off the caliper for picture purposes I guess. There are no missing parts that I could see.
Old 08-24-10, 12:21 PM
danthedj
danthedj's Avatar
thanks again GSteg. I obviously didnt win the kit on ebay (too bad, since it cost nearly nothing to have better brakes). ohh well, im on the lookout for some calipers now. 15mm spacers are needed for the stock 17" wheels or stock 16" wheels? I've got the 16"s for my winter wheels so hopefully they'll clear with some spacers?
Old 08-24-10, 12:31 PM
GSteg
GSteg's Avatar
Both 16 and 17" oem wheels require 15mm spacers. Good luck with your search
Old 08-24-10, 01:07 PM
porn-adkt
porn-adkt's Avatar
16 will not fit.
Old 08-24-10, 01:17 PM
LiCelsior
Retired
LiCelsior's Avatar
unless Ls430 16"s lol.
danthedj, im selling a set if u interested. ill be heading down to philly sat/sun so i can drop them off.
Old 08-24-10, 02:33 PM
danthedj
danthedj's Avatar
if it wont work with my stock 16s then i cant do it yet. Gotta keep the 16s as winter wheels. eeek.
Old 08-24-10, 02:46 PM
GSteg
GSteg's Avatar
16s will work as long as you have 15mm spacers.
Sorry for the bad quality pic. I forgot to set the exposure correctly. This is my spare 16" wheel, but you get the idea.
Old 08-24-10, 03:07 PM
porn-adkt
porn-adkt's Avatar
whats the rotor size? 12.9 ? do you know if TT swaps will fit OEM 16s?
Old 08-24-10, 03:08 PM
LiCelsior
Retired
LiCelsior's Avatar
no lexus oem wheel will fit the supras or ls brakes unless 2nd gen ls wheels, is350 wheels, or ls430 wheels.
GSteg
GSteg's Avatar
The LS400 rotors are 12.4"
I don't know if the 16s will clear supra TT. I wouldn't count on it though, considering there isn't much room left with the LS400 setup.
Old 08-24-10, 03:13 PM
porn-adkt
porn-adkt's Avatar
hmm.. Very interesting. i was almost positive LS swaps would not fit OEM 16s. maybe is because the rotor size? i think TTs are 13 right?
Old 08-25-10, 06:41 PM
PHML
Master Thread Closer!!
PHML's Avatar
16s will fit...just need 15mm spacer...and SAGE front RCA. If you have EXACT front RCA...then you need 17s.
https://www.clublexus.com/forums/sus...o-rubbing.html
Cleet
SC400 / 300 Classifieds
10-02-14 04:08 PM
jdog0411
10-05-11 04:19 PM
Prshrzd
Suspension and Brakes
20
09-24-08 02:58 AM
aliga
05-31-08 09:00 PM
Rhabryn
03-03-03 10:36 AM
Quick Reply: LS400 BBK questions on ebay auction
