I'm lost! Coilovers or Bags?
Hey guys I would really like some help picking between these two.
Please only stick to topic & don't name other brands
If you had to pick, please only pick the things I name.
Thanks
So here is my problem,
I really want bags, but not sure they will last on my every day driving.
The bags I have had in mind is the K-Sport "Airtech Pro Suspension System" which looks like a full kit.
But not sure I want to spend that kind of cash + install.
The other thing I had in mind was to go with the K-Sport Coilovers "Kontrol Pro Damper System" or the "Version RR Damper System"
So if you guys had to pick between these what would you go with?
Also if you have picture's of the K-Sport bags or coilovers could you please post them
so maybe I could pick on my own.
Thanks alot CL
Thanks
Thanks alot CL
Bags... DONE! Ive had mine for 2years+ and still going, I just recently got new bags due to me riding too low other than that they would have lasted forever the K-sports though, you wont have that problem. And yea, if you can install struts and a stereo system, then you can install it yourself. Its quite simple.
I think it looks like bags it is
Just hope there on by "THE PURSUIT"
Only reason I thought about coilovers
is so I have extra cash to to other mods
one is basic kit $2,700
1. 1 – 5gal air tank 9 port
2. 1 – Viair 380c compressor, 200psi 100% duty cycle
3. 1 – 200psi pressure switch
4. 1 – Silencing base plate
5. 2 – paddle valve switch
6. 1 – 200psi dual needle gauge
7. 1 – Bracket for gauge and switches
8. ¼” high pressure air line
9. Power Wire
10. 4 – Full Struts with adjustable lower mount, aluminum top mounts, and 36 levels of damping adjustment
11. 4 – High pressure airbags
the other is a pro kit $3,350
2. 2 – Viair 380c compressor, 200psi 100% duty cycle
5. 2 – electronic switches
9. Power Wire
10. 1 – Fuse Box
11. 4 – Full Struts with adjustable lower mount, aluminum top mounts, and 36 levels of damping adjustment
12. 4 – High pressure airbags
13. 4 – electric Solenoids
14. 2 – ¼” Valves
15. Wireless remote control
If you want to wait like a few weeks(it takes time to ship)
I'm getting the Pro kit
I'll post up pictures & a video
the ksport sucks cuz its manual valves. u gotta run all the airlines into the cabin and behind the paddle valves. electric valves is the way to go
also, it looks like its Front and back adjustments only
Does k-sport make you buy the whole kit like air runners do? Or do they sell the air struts seperate. Their front air struts look similar to the ones from airlift. Sleeve bags require more pressure to lift the car.
also what kit would have these electric valves then ?
sorry im a total noob when it comes to air suspension
not one for Left & right
This is not hydro
PM me a price & where you are in Cali.
That looks clean
