Megan Suspension bottoming out...
I have Megans on lexus 18" rims.
Recently, the left front is scraping bottoming out over bumps. sometimes but rarely the right front does as well but not as much. The rears never do..
I have set the ride height on all four corners at 26 3/4" (measured from the ground to the top of the fender edge using the center cap as a straight line).
Is it just the nature of these coilovers or is it just it a problem with the coilover itself?
with the 18"s, the are almost flush maybe a little tucked...
also I have no spacers up front..
its pretty hard to bottom out Megans since you adjust ride height via shortening the body.. If lowered "properly" only your UCA is hitting the Upper shock tower area.
now if you lowered the coilover via the spring perch this yes your shocks are bottoming out lol.
find out which.
find out which.
