brake problemm !!sc300
did you make sure, you have the slots rotating in the right direction. You will have more of a slight vibration & noise with the slots as they pass through the pad. If you put brand new pads, w/brand new rotors, you had to compress the pistons in all the way to make it fit. That being said I wouldnt think your pistons are bad unless, they are leaking.
ok so one of the front pistons in the caliper are not going back when i try to clamp them back so i can fit the new pads in so the fit over the rotor... one of the pistons those movve back the other doesnt... as for the other which was ok and i got everything in the pads rub really hard so my car cant even role as if the brake are locked in...
MTElnb1
Suspension and Brakes
02-17-08 02:19 PM
