IS250 to 350 Caliper Upgrade... Whats needed?
Old 04-09-11, 01:34 AM
IS250TW
IS250TW's Avatar
^^yes, the 350 rotor
and i dont think there are differences between brake lines don't they?
no, it fits
you'll just have to either trim the dust shield or buy the 350 one
Old 04-12-11, 02:35 PM
lexusis305
lexusis305's Avatar
The 350 cailper fits its yhe same parts but the rotors are diff.
Old 04-12-11, 05:20 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Now that the IS350 AWD has been released (uses the same hubs as the IS250 AWD), you should be able to order the brake setup from the IS350 AWD and use that on your IS250 AWD without issue. I would think anyways.
Jeff
Old 04-15-11, 11:46 PM
Kdash106
Kdash106's Avatar
I think my is350 caliper is from a rwd one, it would fit the awd is250 right?
Old 04-16-11, 12:02 AM
IS250TW
IS250TW's Avatar
yes, it will fit
as long as you either trimmed the dust shield or have bought the 350 dust shield to fit the whole thing
Old 06-02-11, 11:18 AM
DC4coupe
DC4coupe's Avatar
Thanks for the info.
I just noticed my front brakes are starting to squeek on my 250. I'm thinking about upgrading it to the 350 calipers
Old 06-02-11, 11:39 AM
my1s250
my1s250's Avatar
Do it it's a good upgrade.... There is a couple on eBay for $300 for a pair I searched yesterday
Old 06-03-11, 07:17 AM
xnfsx
xnfsx's Avatar
so what is exactly needed to do this upgrade for an is250 awd? calipers off a 350 rwd will fit an is250 awd but rotors for the front will not fit the is250awd but will fit if you trim the dust shield? am i right? or missing something. thanks
mike
Old 06-06-11, 12:08 AM
GiantsFan
GiantsFan's Avatar
so what is exactly needed to do this upgrade for an is250 awd? Calipers off a 350 rwd will fit an is250 awd but rotors for the front will not fit the is250awd but will fit if you trim the dust shield? Am i right? Or missing something. Thanks
please read through the thread!
Originally Posted by 09white250
is it true that you can't upgrade to the is350 brake on an is250 awd?
Originally Posted by asakura58
^ i would like to know as well...having a awd.
Originally Posted by sewell
...it's the wheel hubs. They're completly different. Because the hubs are different its now the cost of the hubs, plus the cost of knew steering knuckles plus the ancillary parts associated with the knuckle. Now, you'd be changing the entire suspension just to achieve a 4-piston caliper set-up.
We have not attempted as with the information above it not worth trying.
Darrel
To sum it all up, NO, you can't just bolt on the 350 calipers/rotors. Now that the 350AWD out, Maybe that will work...
Old 06-06-11, 10:35 AM
xnfsx
xnfsx's Avatar
i didnt said that it will "bolt" right on. I asked if i trim the dust shield of the is250 awd will the rotors fit. However, he was talking about the calipers. So technically your telling me to read the wrong thing. Thanks though.
Old 06-22-12, 08:14 AM
kashmoney1
kashmoney1's Avatar
Yeah I just tried unsuccessfully thinking all you had to do was trim the dust shields, but should of read this first. So will an is 350 AWD rotor fix the fitting problem?
Old 06-22-12, 10:45 AM
my1s250
my1s250's Avatar
what you have so far.....??? My dust shield from the is250 was rubbing against the rotor so I had to trim a little portion off the bottom corner and push/bend the dust shield back a little..
Old 06-22-12, 02:33 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Just buy new dust shields, they're cheap!
Jeff
Old 06-22-12, 07:19 PM
GSE25
GSE25's Avatar
Jeff, would you be able to find out how much of the brake pads cover the rotors on a IS350 AWD?
I'm asking because when my mechanic installed the IS350 AWD rotors on my IS250 AWD and then fit IS350 RWD calipers over, he told me the brake pads aren't 100% covering the rotor. This didn't seem very safe to me so I didn't go through with the retrofit.
However, if you can confirm that the pads aren't used 100% on a IS350 AWD as well, then I might give it another shot.
Thanks!
Old 06-22-12, 07:21 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Define not 100% used? Like a gap between the top and bottom of the pad and the rotor edge and center? How much didn't it cover?
I'm a bit confused.
EDIT: This should give you a bit of an idea how much of the rotor's surface is swept by the pad:
http://i72.photobucket.com/albums/i1...s/PICT0082.jpg
Jeff
Quick Reply: IS250 to 350 Caliper Upgrade... Whats needed?
