IS250 to 350 Caliper Upgrade... Whats needed?
#50
does anyone know if the gs350 awd rotor will fit the awd is250 with the is350 caliper upgrade...i can get some gs350 awd rotors for cheap, just wanna make sure they fit...
#51
I believe thats what a lot of people use as an alternative for the early 250 awds. The gs350 has the same size diameter rotor as the is350 but also has the AWD rotor depth needed
#52
So if I'm understanding correctly; I have a 2009 IS250 RWD. If I want to upgrade to the IS350 brakes I will need:
350 rotors
350 calipers
Shims
Dust shield
And I also believe everything with fit nicely with OEM 17" tires. If im wrong may I please get corrected.
Thank you
350 rotors
350 calipers
Shims
Dust shield
Thank you
#55
350 rotors
350 calipers
Shims
Dust shield
Thank you
350 rotors
350 calipers
Shims
Dust shield
Thank you
#56
