Need advice on buying new shocks !
Old 09-06-10, 11:19 PM
GSRSRT
GSRSRT's Avatar
Default Need advice on buying new shocks !
Sup CL time has come for new shocks what do you guys recommend and im not buying coil overs i just need real good shocks to replace the OEM, i have $900 to spend let me know thanks
Old 09-06-10, 11:22 PM
VNN326
VNN326's Avatar
get some coilovers. if you must get shocks i would get bilsteins.
Old 09-06-10, 11:25 PM
GSteg
GSteg's Avatar
$900 is twice the price of most shocks. You can get a set of OEM shocks for about $300 shipped from Sewell Lexus.
If you want a slightly stiffer ride, Bilstein HD shocks are about $500.
Old 09-06-10, 11:26 PM
GSRSRT
GSRSRT's Avatar
i would but not for my 99 GS300 because im gettin it ready to be shipped out to my country and will buy a 03 or 04 GS430 and start my build with that! i just need good shocks to last
Old 09-07-10, 12:14 AM
Silver'04
Silver'04's Avatar
I was also in the same boat as you. Depending on what your goals are with your suspension set up, but if you're just looking for factory replacements, KYB GR2's should be more than enough, even if you plan to lower the car in the future. I researched for a little while and while a lot of people will suggest coilovers, they may not be what you need or want. I recently installed a set of Bilstein HD's along with my Tein Stechs and Exact/Sage RCA's. I got the ride height I wanted and the ride quality I'm almost sure I couldn't have gotten with coils. The ride is firm, but very comfortable (IMO). It's not bouncy and harsh like most coilovers on the market. I think as far as level of comfort (from soft to firm) it goes : KYB GR2's > Bilstein HD > Bilstein Sport. Good luck
Old 09-07-10, 12:29 AM
GSRSRT
GSRSRT's Avatar
Thanks guys now i know what to do, will let you know when i buy them and install them thanks again for the good advice.
Old 09-07-10, 07:14 AM
Grantville
Grantville's Avatar
Here is what I did to my 02 GS, Diazen bushings everywhere, UCA, lower ball joints, tie rod ends, Tein H Tech (the smallest drop and softest of the aftermarket springs), and KYB GR2. The Diazen sways would have been added but they are not available. So your choice for sways is urethane bushings for stock bars (my choice) or TRD blue, which are very stiff.
This will have a very nice improvement in the handling department with only a slight increase in how firm the ride is. I have the Eiabach & Bilstein HD on my 99 GS and it is lower and rides firmer, but I the handling is not that much better.
Old 09-07-10, 09:38 AM
acnup00tl
acnup00tl's Avatar
i just bought mine form the dealership for 125 for the pair. The funny thing is the SPORTDESIGN shocks are cheaper than the standard GS shocks. You would think SD shocks would be more.
Old 09-07-10, 11:27 AM
werewolf
werewolf's Avatar
Are the SDs stiffer?
Old 09-07-10, 11:38 AM
acnup00tl
acnup00tl's Avatar
I wouldn't be able to answer that , I have a Sportdesign model so I really couldn't say if they are stiffer than just regular shocks on a regular Gs. Thats really one of the only things different than a regular GS other than wheels that are graphite color and a couple other minor tweaks .
Old 09-07-10, 11:58 AM
Doneve79
Doneve79's Avatar
Hey guys, is it better to do both of the front ones or can i do just 1? i have 1 bad one right now...
Old 09-07-10, 08:07 PM
5t341th
5t341th's Avatar
do it in pairs
Old 09-07-10, 10:29 PM
GSRSRT
GSRSRT's Avatar
what if i do the Eiabach & Bilstein HD with the TRD Blue sway how would that be and how is the bilstein compared to the KYB
Old 09-07-10, 10:37 PM
istundra
istundra's Avatar
Suppose to be L-tuned shocks and stiffer...
Does any1 have the part #?
Thanks!!!
Old 09-09-10, 05:49 AM
raceforgt
raceforgt's Avatar
Thumbs up
GSRSRT- that's the exact setup I want to go with. I have the Eibach Pro Kit already, just need to install. I want the Bilsteins and TRD sways next. Anyone with any thoughts on this setup? Im also one not looking to stray too far from stock ride/feel/height. How would this compare??
new to CL-thanks for any help!
Quick Reply: Need advice on buying new shocks !
