people running koni yellows, what springs are you using?
the previous owner of my car installed koni yellows, but im not sure what springs were used. i would like to get more of a drop out of the setup if i could. if i cant get a decent dop by adding springs or maybe adjusting the height with the konis ill just spring for some coilovers. if im not mistake you can only adjust the firmness and softness with these shocks right? heres a few pics to try and aid in anyone recognizing what springs were used.
![](http://a.imageshack.us/img85/6416/img22281.jpg)
![](http://a.imageshack.us/img46/2938/img22341.jpg)
i am running koni yellows for a supra with swift springs. i love my drop but im not sure exactly how much it is.
you can adjust the rebound on those, but if i recall you have to remove them to do so.
Swift springs lower the Supra by 1.2/0.8, although the springs above don't look like Swift to me.
Why not just clean the springs and look for the label?
I don't know how many variations of Koni shocks are available for the Supra, but I do know the current ones have 3 settings for the perches. The perches are spaced about 12mm apart form one another.
and yes i think you do have to remove them for adjustment.
this is how the car currently sits. the rear is ok but the front seems to be up a bit more based on the wheel well gap
![](http://a.imageshack.us/img443/9849/img2229rv.jpg)
yahoo, how was your setup? do you have any pics?
ok if i am understanding you guys correctly i can move the circlip to the lower position which is that notch showing below where the perches are currently at in this picture?
![](http://img827.imageshack.us/img827/8885/img22351.jpg)
![](http://farm3.static.flickr.com/2546/3818672683_a89d933192_b.jpg)
That sounds about right. Once removed you can take that small ring off and lower it to a different perch.
yeah i did a search for some posts by you to look at your drop. looks great!
id like to be about about where yours is. im going to switch the perches to the lower position and see how i like it and if i want a little more ill get a set of springs.
Luxor
SC400 / 300 Classifieds
03-23-16 03:44 PM
