2 Questions : Garage door opener + Brakes
Garage Door opener:
Is this think a PITA to get to work or is there a trick...
I get the flashing lights that say I have reset the codes. But when I go to hold the button down + hold the opener button down, I never get the flashing light???
Brakes:
I installed brakes 1 year ago, and the other day I noticed that if I stand on them. I can get them to the floor... The stopping point is mid pedal but again I can get it to the floor, is this normal?
Fluid level is fine and pads are not worn.
Brakes:
Garage Door opener:
Brakes:
Brakes:
have you bled the brakes lately? that just requires 2 people one to pump and one to release and close the valve on the caliper. aftermarket lines are a good idea as other have posted. i have the goodrich ones on mine. love it.
link to a DIY for bleeding brakes
http://www.lexls.com/tutorials/brake/bleeding.html
hope this helps
Thanks for the handy bleed your brakes link. Know I know the technical methods to bleeding and not the ancestral way my father taught me.
The garage door thing is still not working. When I reset the codes. I press any button and it just slow flashes. It never does anything else. So here is the exact steps I did.
Erase codes (hold outer most buttons till they blink fast)
Press and hold any button (starts to flash slowly immediately, directions say should take 20 seconds)
While holding that button press and hold my garage door opener ~1-3 inches away with the battery facing away
Nothing happens.
Way 2:
Get out of car and press "learn button"
Get in car. Press and hold any button (starts to flash slowly immediately, directions say should take 20 seconds)
Nothing happens.
Nothing happens.
Way 2:
Nothing happens.
