Drive lots miles....lower car?
u would have bad tire wear if you drop your car really really low and as a result u will start to have negative camber. tires will wear out faster due to really bad camber.
if you drop your car just make sure you get an alignment to help with the camber problem.
but yah, lowering the car does improve on the handling. I mean the f-sport springs is a good place to start. it is a conservative drop. some people on CL dont even consider f-sport springs as a drop, but there is a difference. plus going the springs route is a good economical decision if you dont want to spend a lot on getting your car lowered.
hey mahcah, you may not need it. if your not going to slam it, the alignment place should be able to set your wheels back to factory specs. i am confident if you take it to an alignment place that does a good job, they should have no issues doing it.
Tech Info Resource
Is this on the front? If it is, your subframe needs to be adjusted to the right a little to balance out the camber. Once this is done, you'll need to adjust the toe, and you'll likely not have any wear issues. Saying camber is a primary reason for inside edge wear is usually wrong.
Yes its the front. If I understand correctly, the toe would be the bigger reason for inside edge wear no?
So should I ditch my IS300 front camber kits? or keep them to get my camber "green?"
BTW my toe is at .03 (l) and.02(r) which is spec range. So if I decide to return the camber kit, I'll have my alignment person to adjust the subframe and re adjust the toe then.
Tech Info Resource
