Anyone got a real clear picture of the Brake Booster Line?
Not finding any good ones on Google-.- and can't seem to find any through search on here. A picture of that or the PCV valve will work.
Thanks in advance.
Thanks in advance.
first of all what GS are u talking about (the 300 or the 400 or the 430) important for us to know. Second none of the GS have a brake booster line ....there is no brake booste....all GS have a little compressor and little tank (all in one). third of all if u cant find the PCV valve ....then maybe u should take ur car to a mechanic ...you will be better off
Just seafoaming and need help locating the valve to pour the seafoam into, not changing anything.
Read that the PCV or (as I read people said) the 'brake booster line' are the two vacuum like valves that everyone uses to pour it into.
i did the seafoam on my gs400 last weekend ......lolll what a coincidence..... i did it so slick i didnt even need another person....made a hose out of 3 diff size hoses >>>>from big to smaller to smaller......why i did that ....well its much better then pouring the seafoam ...why >>> cause it kills the engine if u dont have someone help u .....also IMO i dont think its good to poor it in since u wanna get the foam in there slowly for a even spread.....
Yes u got it that is the PCV valve but DO NOT pour it into the PVC (i am assuming u already know that)....ohhh boy i need to make a little write up on it ..
Ill do one tomorrow
Ill do one tomorrow
I was reading into it on the forums actually and people said they use the PCV, but do not pour it in fast and whatnot. Pour it in 'sips' and above the valve to mix it w/ the air so it doesn't flood the engine.
https://www.clublexus.com/forums/gs-...d-seafoam.html
