Megan ez coilovers?
#197
Does anyone know the Minimum amount the Megan EZ Coilovers will lower a 2WD IS250? I'm trying to decied between H & R Springs or these coilovers. I'm going to be having a set of 20x8.5 with 225/30 tires (+40mm offset) and I want to try to avoid rubbing issues. I know I may have some rubbing, but I don't want anything extreme...Thanks for the info!
^ Found the answer, nevermind!
#198
Recently installed these on my 08 250 AWD, as stated before I get a slight vibration when in drive at a stoplight which I can live with. My question to those that are AWD or RWD w/auto trans do you feel the trans shifting/down shifting a bit more than stock suspension??? Or am I just crazy? Lol
#199
My Megans arrived today, i noticed that the 2 front are adjusted exactly the same and same thing for the rear, my questions is how low is the standard setting when it come in the box? Did any body install straight from the box? I'm kind of clueless as far as to how do I know the mesurement on the coilover I need to go about the drop I want? Any hints pictures of ideas are greatly appreciate!
#201
Thanks, i'll probably do the same and see Where that leaves me.
#202
Check your cv boot once in a while, many people have reported (including me) that the cv boot will tear over time.
#204
i kept it at manufacturer height and i have AWD.
i'm running 19x8.5 all around, no rub at all but i scrape on steep declines if i don't take it slow. wheel gap is gone.
i also experience the vibrations but i'm used to it now.
#208
Hey, I have a gs300, I found te Megan racing coilovers for like 650 and I wanna know how low I can take these. It saa these only go to like 15 or sumthing and the ksport coilovers have like 32 for adjusting? I'm assuming the more u can adjust the lower u can go, does anyone have pics of gs300 slammed or atleast fairly close to the ground? Post pics let me see if you have. That'd b really helpful for me. Thanks
#209
These can be adjusted to be VERY low, we have few members here who are slammed on megan EZ.
Check this lowest of the low thread and look for people who are on megan ez coilovers.
#210
Coilovers are adjustable to whichever height you desire, it is 100% ok to close the gaps, I'm not slammed on my Megan EZ, I wanted them just to close the gap as well.
