Outer Tie rod frozen - help?
Old 01-30-11, 04:43 PM
AshburnM3
AshburnM3's Avatar
Torch the nut until it turns orange color works for me
Old 01-31-11, 07:59 PM
RoboRam12
RoboRam12's Avatar
Originally Posted by Coco-bun
Considering you're in Ohio (salt belt) I bet that thing is pretty frozen on there. I had one hell of a time doing mine because I don't have a lift and since I couldn't get the car up high enough, I couldn't get a cheater bar. Kicking it is an option but you also have to hold the inner side as well which makes it a pita.
Try soaking it with PB blaster for a night or two prior to the day you plan on working. Apply heat on the outer tie rod end (I'm always hesitant to apply heat on metal to parts i'm not replacing...) and give it a try.
good luck!
Yeah, I'm going to give it another try soon. Maybe not this week, but it needs to be soon since I have an inspection coming up and need new front tires.
My instructor was hesitant to do that because he didn't want to boil the grease out of the ball joint, so we didn't do it.
HtownBlue
09-18-22 07:26 AM
freshmoney
Suspension and Brakes
07-24-14 10:49 AM
gtstcactus
02-12-14 10:07 PM
Horsepwr
03-05-10 09:10 PM
CantSeeMe
02-11-08 01:41 PM
Quick Reply: Outer Tie rod frozen - help?
