ls400 rotors rubbing on outer tie rod
Old 10-22-10, 03:03 AM
soarer13oy
soarer13oy's Avatar
Default ls400 rotors rubbing on outer tie rod
I finished installing my ls400 brake set up today and noticed some rubbing. I checked it out and found out that my damn outer tie rod is rubbing on the driver side rotor. My freakin brand new rotor is a bit damaged from this. Is my alignment way off or something? My car doesnt pull to the left or right. This is a freakin bummer.
Old 10-22-10, 05:44 AM
5sp_jzz30
5sp_jzz30's Avatar
picturs please. either you installed something completely wrong or you have a bent upright.
Old 10-22-10, 06:07 AM
YeA 2jZ
YeA 2jZ's Avatar
^^^very true, please post pics
Old 10-22-10, 08:04 AM
soarer13oy
soarer13oy's Avatar
Il have pics up as soon as i get off of work. I dont really see how i would mess up installing this as the calipers just bolts right up and the rotors just goes right in, but im hoping i did lol
Old 10-22-10, 06:24 PM
soarer13oy
soarer13oy's Avatar
help......
Old 10-22-10, 07:04 PM
soarer13oy
soarer13oy's Avatar
the passenger side has about almost 1/2" clearance.
Old 10-22-10, 07:35 PM
//LRD
//LRD's Avatar
Compare the length of your tie rod end to another one..
Old 10-22-10, 08:39 PM
good2go
good2go's Avatar
Originally Posted by soarer13oy
help......
Is it just me, or does anyone else think that ball joint looks a bit too laid over?
Old 10-22-10, 09:21 PM
soarer13oy
soarer13oy's Avatar
So do you guys think that the outer tie rod has been shifted outwards too much causing the ball joint to be laid over? I had sears do my alignment. I have a vid that i am uploading.
Old 10-22-10, 10:12 PM
k7q
k7q's Avatar
Maybe a bad or loose tie rod? Move the knuckle left and right to see if it has play.
Old 10-22-10, 10:13 PM
k7q
k7q's Avatar
Orrrr MAYBE a bent knuckle? But not likely
Old 10-23-10, 12:33 AM
soarer13oy
soarer13oy's Avatar
Ok so i put the rotor on and hand spun it. This is what happens. Does it seem like i will have to replace this whole part?
http://www.youtube.com/watch?v=gCIDRmX06Lo
Old 10-23-10, 12:46 AM
good2go
good2go's Avatar
^^ dude, that rotor is either mounted incorrectly, or it's severely warped
Is that some cheap ebay rotor ?
Old 10-23-10, 12:54 AM
soarer13oy
soarer13oy's Avatar
Yeah its a cheap ebay rotor. So to you its the rotor? I was thinking it was the hub or whatever its called. How would i check to see if its the rotors?
Old 10-23-10, 01:02 AM
soarer13oy
soarer13oy's Avatar
How can the rotor be mounted incorrectly?
Quick Reply: ls400 rotors rubbing on outer tie rod
