HELLP sc300 the rear sways right to left when driving!!!!
when i drive about 50mph and go over uneven surfaces the car feels lyk there is a loose tire in the back or control arm? does anyone know what this is?
im pretty sure its the rear control arms but i already changed this ..should i get megan control arms? you can tell when you raise your car up and shake the tire it shouldnt move if it does then your arms are bad i guess.??
I have the same problem! And i tried putting my car up on stands and moving the tires but they did not move! But i was looking around trying to move the control arms and i could not move anything except the rear sway bar. when i went to move that it moved with a small amount of force so i dont know if that means we need new rear sway bars or what lol. I was thinking about getting the Taabe sustec sway bars any ways. But i have been looking around trying to find out if supra sway bars work on sc's if any of you guys can tell me if they do or dont ill order them and see if that solves the problem.
I had this problem in my s13.
I replaced any ****ty control arms, didnt help.
Subframe on my car was bent out slightly, that was half the problem.
Other half was uneven coilovers.
Measuring tape for next time
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Do you have excessive negative (-) camber in the rear? I notice driving my brothers accord with ridiculous rear camber that the back sways back and forth alot and it never did before the stupid camber adjustment
I'am currently dropped on tein springs 2 inch drop with 18 inch wheels. The tires in the back are 265/35/18 pretty big and slight negative camber.. but I'm going to tire kingdom tomoro to check this out. I doubt its the sway bars tho because it feels lyk its one tire thats loose or pulling to one side only..?
I would check your driver side rear strut. Mine did the same thing, but swayed or bucked to the right going over uneven surfaces. I checked my suspension components and first thing I noticed was the passenger rear strut was leaking. I was fortunate to be able to purchase a set of coilovers and the problem went away, it's rock solid now.
mayb my strut is leaking I saw some green fluid around it..but would that cause it to swerve ... doesn't a strut just absorb vertical impact and control arms hold it in a straight line?
If it is leaking should i just replace the whole strut then how much does that usually run?
