Help needed- installed Mark IV supension, now looks like an F-150
Old 10-30-10, 01:52 PM
Hbro
Hbro's Avatar
Default Help needed- installed Mark IV supension, now looks like an F-150
Is this a bad install? Incorrect parts? (purchased from a forum member)
2 1/2 gap in front.
Drives great.
Easy fix?
I like the shop that installed them and do not want to create a problem until I can explain what is the problem.
http://s1026.photobucket.com/albums/y323/Hbro111/SC300/
Old 10-30-10, 02:39 PM
abounly
abounly's Avatar
should be lower than that.. did the suspension settle?
are you sure you got tt suspension?
Old 10-30-10, 03:53 PM
imDementeD
imDementeD's Avatar
and did you get supra springs and struts or just springs?..just springs will make it sit higher..i just installed supra suspension and mine is definitely noticeably lower..however i have a lean to my car now the driver side sits lower then pass in the front by about an inch
Old 10-30-10, 11:30 PM
lev00221
lev00221's Avatar
I think that the whomever installed your springs may have reversed the springs front to back. That is, front springs in the back and back springs in the front.
Old 10-31-10, 05:34 AM
Hbro
Hbro's Avatar
My first thought was that the springs were reversed.
Old 10-31-10, 10:30 AM
turbodremz
turbodremz's Avatar
something is definitely wrong there. Should be much lower than that.
Old 10-31-10, 05:21 PM
slappy96
slappy96's Avatar
This is the issue. All Supra TT components have to be used. You cannot mix/match SC springs/struts with TT springs/struts. Or...you don't have TT components. I suppose you'll have to take that up with the seller.
Could go rock crawling though
Old 11-10-10, 12:20 PM
Boergy
Boergy's Avatar
Hello!
I had the same problem on my 97´SC400 with a Bilstein-Supra Suspension. on the rear was lower and ok, but on the front, i had the same high as with the original suspension!
The good was, the Bilstein-damper have rings and i maked a new groove for the fixing ring of the spring disc.
I think, you have only the normal damper, or?
greets
Tom
Old 11-10-10, 06:30 PM
Pipe
Pipe's Avatar
i just bought mine yesterday hope i dont have that problem ,but then again im a mechanic and i could clearly tell whats the front from the rears
Old 11-11-10, 07:07 AM
Hbro
Hbro's Avatar
I ordered lowering springs. Regardless of how my setup turned out I want to go lower than the stock MK IV. It would have been impractical with my front lip. I broke that for the 3rd and last time.
Old 11-11-10, 09:13 AM
slappy96
slappy96's Avatar
Originally Posted by Boergy
Hello!
greets
Tom
Good call, I totally forgot that the Bilstein dampers can come with the groove for the seat ring in two different places. This may have been in the higher groove.
Old 11-11-10, 10:17 AM
Boergy
Boergy's Avatar
HY!
I bought a used Bilstein-Supra Suspension, this have the ring, but only one groove. i made the 2nd croove self. you can look in my thread my SC
greets
Tom
Old 11-18-10, 05:59 PM
ashtray
ashtray's Avatar
Thats how my sc sits on kyb gr-2's lol love that offroad status until I'm dropped on espilir springs.
OP: are you sure those are TT?
Old 11-19-10, 03:19 AM
v8soarer91
v8soarer91's Avatar
you have been sold soarer suspension.
sell what you have got and get some coilovers where the height is adjusted with a movable base bracket, so the spring seat only needs to be adjusted to keep the spring captive and damping adjustment.
mmm nice front brakes
Old 11-19-10, 09:28 AM
Hbro
Hbro's Avatar
I bought these from a forum member. I tried to contact him to confirm they were from a TT. No reply.
I am having TT lowering springs put on the car Monday.
Quick Reply: Help needed- installed Mark IV supension, now looks like an F-150
