BBK Question
isf brakes or z06 brakes wouldn't be hard to do on a 2gs...its just getting the caliper bracket made and the correct size rotors...Im sure you can use the ISF rotors and make the caliper bracket to fit. I had the z06 calipers front and rear done for my 01 silverado...a guy saw my setup and took my brackets and made them out of billet...now lots of silverado guys are rocking z06 brakes on their trucks.
keep us informed
also why not use the z06 rotor? how tall is it compared to the isf rotors? im 99% sure the z06 rotor would be significantly cheaper
Like you, I'm VERY interested in seeing the results for this customization.
im def interested in this ESPECIALLY if i end up getting that motor. i have had this LS mini BBK at my house for a month or two and havent mounted them
any target price or ballpark price?they ONLY gonna do the fronts also?
I'm leaning toward the fronts only at the moment. If all goes well and it works out. I will list all the places to get everything you need at the lowest prices possible. So others can follow the same route. I'm not looking to make any profit, just trying to help the board out.
The biggest thing is getting the brackets(I don't foresee these going higher than 200$...I'm not the manufacturer so I don't know). I'll give it a shot, once it is shown that it works on the GS(I have a first gen). I'll ask the member who makes brackets to see if he would be happy with a group buy or something. Otherwise, you guys will just have to buy on an individual basis.
I don't mind being the test subject in this experiment, If it doesn't work, then its not a big issue. But I would hate to mention this BBK possibility, and then have other members spend some cash and find out that for whatever reason it does not work on the GS series vehicles.
I forgot to mention the IS-F rotor is 14.2", and the Zo6 is 14".
LS400 rotor is 12.4"
1993-2005 GS300 rotor is 11.65"
have the weights on the rotors? calipers of the ones u using?
i would love a all around BBK but will settle for a front only....let us know
sorry in a hurry going to lunch with the kiddos
A little tip for the OP to think about.. Since the Master cylinder on the 2GS is designed with a certain orifices to push certain amount of fluid thru at a certain time, with you upgrading to a larger caliper and more clamping force, you might want to address that you will need to properly match the fluid rate to the caliper because the last thing you want to do is go 80+mph and step on the brakes and have it not fully clamping down therefore running into something or worst someone. Just a thought to keep in mind. That's why most people who upgrade to bigger caliper use aftermarket master cylinder.
I have a set of used stoptech fronts only for sale at a great price for $1300, the kit has about 6k on it since I had it last year, its in great shape to say the least. It is in red calipers with slotted rotors. Nice upgrade over LS400 brakes for sure. Awesome pedal modulation since the caliper has minimal flex. 2 piece rotor looks great also an added advantage in weight savings.
PM me if you are interested!
https://www.clublexus.com/forums/sc4...brake-kit.html
You probably won't need the rears but if you get on the brakes hard enough the rears will fade also. Especially when you do a few 100mph to 30mph stops.
Making brackets to make the caliper fit seem a bit unsafe. Those brackets don't look very sturdy?
