SC430 Radio
I have a 2003 SC430 radio and have had problems with the CD jaming. Now the CD will not eject. Any idea's other than replacement and if so, where can I get a good used replacement?
Tks.
Tks.
1. this is a suspension/brakes subsection
2. you posted in a completely wrong subforum...read carefully, it says SC300/400 NOT sc430
3. take the radio out and give it to competent electronics specialist to disassemble to diagnose the problem.
4. most likely replacement radio will be the cheapest alternative since diagnosing the problem by a specialist will cost money even if he cannot fix the problem
good luck and next time make sure you post in the correct subforum. you wont get much help with this issue here.
