whole rearend moves
so i replaced my sub frame after it cracked while i was driving (scary stuff) but now tht its replaced and im driving itll go fine while theres no bumps but once i hit a bump or anything the front is fine but the whole rear end moves like its moving side to side its scary and i dn wanna drive cuz i feel like ill break sumtin.
i dnt see how the whole rear end would move. the sub frame is bolted down and not loose at all i alrdy checked that
any ideas? any help would be great i rly neeed to get my car back on the road
it is a 92 sc400
it is a 92 sc400
So let me get this straight. You replaced the front or rear subframe. The front is aluminum & the rear is steel correct. You did make sure the rear diff is tight & all the bolts are in it. Also the rear sway bar is connected. Maybe the rear bushings on the back of the diff ar waisted. If you replaced the rear subframe.
i replaced the rear subframe and the sway bar is in place its old and rusty tho (1992) everything is bolted down nice and tight the bushing on the subframe are good. im not too sure about the control arm bushings tho. could that be a possibilty if so how can i check the bushings? and what are sum cheap ones i dont wanna spend too much ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
also could jus be that i need an alignment? i havnt aligned since ive changed the subframe.
I'd say if you go over a bump and the rear end sways... its dead. Have a friend drive alongside you and if your wheel is moving up and down when you're going 70, your shock's dead. That's how I figured out which side was dead last time.
if my shock is bad do i have to replace the entire strut assembly or can i jus get a shock? and would it be better to do both sides evn if only one is bad? and last question can i do this myself or will i have to go to a shop to get it done? i do have quiet a bit of knowledge of doing work on cars
1-spring compressor
2-impact air/electric
3-friend
If your dampeners are blown you should be able to stand behind the trunk and push down so the springs compresss and let go. when it rebounds the car will keep bouncing up and down like a caddy if they are bad. the shocks keep the springs from bouncing forever if it goes up like 1 or 2 times they are prolly good if its still bouncing by itself after 2 they are prolly blown. just start bouncing the rear and see if its recovering quickly. hard to explain in words.
3rdelement
03-06-06 05:35 PM
