2001 + brake master cyl
Old 11-15-10, 04:39 PM
porn-adkt
porn-adkt's Avatar
Default 2001 + brake master cyl
i heard they were redesign in 01 internally. Did they change externally? meaning plug location and such?
i read that there is only one plug to change, can anyone tell me which one and if it is the same thru 05 (01-05)?
Any pics of 01-05 master would be appreciated.
Here is a PIC of the 98-00 unit
Old 11-15-10, 07:21 PM
porn-adkt
porn-adkt's Avatar
Can some one please post a pic of their 01-05 Master..
thanks
Old 11-15-10, 07:30 PM
AMSMIKE
AMSMIKE's Avatar
2003 GS300
Old 11-15-10, 07:34 PM
porn-adkt
porn-adkt's Avatar
AMSMIKE.. Ur da MAn, thanks much brotha..
now are they the same for 01-05?
I see the different Sensor... :-)
Old 11-15-10, 08:49 PM
EMOgs3
EMOgs3's Avatar
Off topic but... Does anyone know a place where i can fix my bmc? it makes a beeping noise when i brake.. kinda annoying
porn-adkt
porn-adkt's Avatar
i think sewel sells a rebuild kit which is the plunger, but no rebuild for anything else, just replacement which is $$
So anyone know if 01-05 are the same unit?
Old 11-15-10, 09:25 PM
Dueces
Dueces's Avatar
this may help read what SorrGwa says
https://www.clublexus.com/forums/gs-...e-booster.html
Old 11-15-10, 09:31 PM
porn-adkt
porn-adkt's Avatar
Thanks Dueces.. SO i guess 01-05 are the same
Old 11-15-10, 09:42 PM
Dueces
Dueces's Avatar
yeah the 01 model is where they made the change on that one sensor
Old 11-15-10, 09:50 PM
KingNasGS4
KingNasGS4's Avatar
Are you guys sure its with the 01 they started? or later? I recall test driving a few GS 430's late last year and hearing the buzzing sounds. But they both were 01's
Old 11-15-10, 10:03 PM
Dueces
Dueces's Avatar
i think ****-adkt just wanted to know if the 01-05 master cylinders were the same and yeah they are. the difference between the 98-00 and the 01-05 is the brake pressure sensor the prong setup is different. i was told that the 01-05 are better than the 98-00.
Old 11-16-10, 04:24 AM
SorrGwa
SorrGwa's Avatar
the buzzing sound is the brake booster building pressure or even the abs pump.
if its an annoying beep, thats the abs warning.
Old 11-16-10, 05:50 AM
Dueces
Dueces's Avatar
Thanx once again SorrGwa for the help
Old 11-16-10, 08:35 AM
ElitistK
ElitistK's Avatar
before you guys waste all that money by getting another brake master cylinder, check to see if the seal for the nitrogen tank is bad or not. most of the time, the nitrogen tank that boosts the bmc is out of nitrogen, hence you experience brake failure and all sorts of other problems.
Old 11-16-10, 08:39 AM
porn-adkt
porn-adkt's Avatar
interesting. How does go about getting it refilled? i would assume you need the correct tools and nitrogen.
Quick Reply: 2001 + brake master cyl
