NEWBIE<---- in need of some serious help ...buzzing sound coming from my brake pedal
Old 12-02-10, 10:43 PM
johnsgs300
johnsgs300's Avatar
Unhappy NEWBIE<---- in need of some serious help ...buzzing sound coming from my brake pedal
well first off hey everyone thanks for looking at my post this is my first forum ...ever .....and also my first gs300 i bought it about a couple days ago and im kind of regretting it becuase im not sure what this is .....so when i step on te brake driving slowing i here a bzzzzzzzzzzzzzzzz sound comign from the brake pedal ..someone told me its my abs pump ..and that $1100 !!
so i luckly found a crashed car and got one off that changed it and now im getting the same thing but only now when i brake my car is pulling to the driving side .....someone please help me
Old 12-03-10, 04:34 AM
ThomasGS4
ThomasGS4's Avatar
You should've come onto here first. That buzzing noise is completely normal; everyone's GS on here does that! If you put the car in the "on" position without starting it, pump the brake pedal and it will come on again.
As for pulling to the right, I'm sure that's something else maybe brake pads?
Old 12-03-10, 04:44 AM
Mr Jokster
Mr Jokster's Avatar
If the pulling wasnt there before, you more than likely need to bleed the system. When you replaced the pump, you may have gotten an air bubble on one side. This happened to a friend of mine when he changed his booster.
Old 12-03-10, 04:45 AM
Mr Jokster
Mr Jokster's Avatar
oh and the buzzing sound is the pump adjusting pressure Whoever told you what it was was correct, but never said exactly what was going on
Old 12-03-10, 08:30 AM
johnsgs300
johnsgs300's Avatar
Yea the pressure sound I hear but this is more of like abs kicking back on the pedal like a loud buzz I actually feel it on the pedal
Old 12-03-10, 08:48 AM
johnsgs300
johnsgs300's Avatar
Old 12-03-10, 11:21 AM
johnsgs300
johnsgs300's Avatar
i just dropped it off to a shop he said it proballys needs bleeding like mr joker said and as for the abs kicking back maybe a sensor? well hopefully its nothing major ill keep this updated thanks
Old 12-03-10, 04:00 PM
porn-adkt
porn-adkt's Avatar
what year car? what year unit? what do you mean by kick back? is their hydraulic release or sound below 5mph to a stop?
Old 12-03-10, 06:31 PM
johnsgs300
johnsgs300's Avatar
its a 2000 gs300 with 2000 gs300 pump and its hard to explaim its like if your drive slowly and then stop slwling when u come to a complete stop u feel the pedal kinda kick back and go bzzzzzzzzgrrrrrrr for a second or 2 if the radio is on its not a bother but just cruising at night it def is
Old 12-03-10, 06:37 PM
johnsgs300
johnsgs300's Avatar
okay so i bought an entire brake unit amb pump everything for $150 and they go on ebay for $400+ my mechanic charged me $60 to install it and its still doing this buzzing sound when i brake and its still pullling to the left .......he also said it might just be a wheel sensor ?????? he said seeing that ther are no lights on maybe they need cleaning .......im not sure and he said my steering wheel is supose to turn back to me freely when i make a turn <<--------i didnt realize ive always had crappy cars untill now lol ........so to fix that he said it could be my rack and pinion ?
Old 12-03-10, 08:51 PM
ThomasGS4
ThomasGS4's Avatar
Dude...we already established that the buzzing sound is completely normal.
Old 12-03-10, 09:12 PM
johnsgs300
johnsgs300's Avatar
its not the pump npise ther tryiong to fix the amb is kicking back on the pedal and making a buzzzing sound .....i know about the regualr one
Old 12-03-10, 10:58 PM
porn-adkt
porn-adkt's Avatar
The sound is a pressurizing sound that is normal to all units. it sounds like a fuel pump pressurizing. hard to explain but that's the sound it should make, a healthy pressurizing sound.
The buzzing is NOT normal, the Buzzing is failure to the ABS unit. To be honest when it happened to me i was never able to completely diagnose the source of the problem since i never got a abs/VSC light. i got it scanned any way and DTCs came up. it was like they were hidden like a fawking Herpes virus in your spine.
after it was cleared the ABS took a dump, releasing pressure in lieu of kick back.
like you i change to another supposedly good pre 2000 unit and same thing happened. the pulling to the side is the VSC/traction control, which is controlled by the ABS and all other sensors (Yaw rate sensors, Speed sensors, and deceleration sensor) in my case the unit would apply hydraulic pressure to the right side of the car causing me to pull right. it was only from a dead stop. then it would go away.
Old 12-03-10, 11:28 PM
johnsgs300
johnsgs300's Avatar
Smile
this sounds exactly like my problem ................i have no lights or anything either .........so what should i do to fix this problem...so i dont have to play trail and error with my mechanic and go broke lol how did u finally get rid of this problem ?
Old 12-03-10, 11:36 PM
porn-adkt
porn-adkt's Avatar
Originally Posted by johnsgs300
this sounds exactly like my problem ................i have no lights or anything either .........so what should i do to fix this problem...so i dont have to play taril and error with my mechanic and go broke lol how did u finally get rid of this problem ?
you need to get your codes read, it is an enhanced reader not the regular autozone type. my mecahnic was able to read it for me for free which is generally a $80 charge. lexus charges $180 last time i checked. Go from there to see what you pull up. if not maybe swap out for a 2001 plus unit.
BTW i have a unit that was swapped out with 03 abs/ and booster, if your interested let me know.
Quick Reply: NEWBIE<---- in need of some serious help ...buzzing sound coming from my brake pedal
