Tanabe Sustec NF210 ??
Hi, does anyone have any info/experience with these springs? I have an 07 is350 and I'm debating if i should do a minimal drop or just keep it stock. My main reason for lowering is for appearance, so I do not want to sacrifice the stock ride feeling, and coils are out of the picture...I did not find anything from searching, so any help or info would be greatly appreciated...thanks
I'm still undecided if I should go with springs or coils. Springs won't give you an even drop on an AWD which is what I have. But if I had a 350 and was looking for a minimal drop I'd go with the fsport springs and shocks. They are specifically designed for the car. Don't forget to buy the shocks either. They are a main part in a suspension and you'll need them to keep your ride comfort on the shorter spring
The speculation about stock struts wearing faster doesn't mean anything, especially since the car doesn't have struts.
I've been riding on NF210 for almost two years now. Comfort is as good as stock. Huge improvement in body roll compared to stock. No clunk noise or rubbing issues. The only regret I have with the NF210 is, its not a even drop. The front is a tad bit higher than rear HOWEVER, you dont need to worry about speed bumps or driveways. Its also perfect for the horrible winter here in Canada.
You can check out my thread (on my sig) to get a better idea on the drop. You must understand though, I have an AWD so the drop is a big difference. However comfort and handling will be the same. I would recommend this spring if you don't mind front a tad bit higher.
Tanabe NF210 springs are actually the same drop on a RWD 350/250. The front is a tad bit higher too. It was the design of the spring.
andy350
Suspension and Brakes
13
06-18-13 04:34 PM
