Seeking guidance Espelir ASD Springs & Tokico HP Shocks
I want to run Espilir's on the front of my car. The Tanabe NF210's I installed on my Tokico HPs didnt lower the car enough. But its a major improvment from stock.
Tip:
Drivers front - You have to pull back the fender liner on the front and unbolt the washer bottle. This will provide the clearance required when you remove the long bolt that is in the upper control arm. When you are installing the struts, re-install that long bolt backwards (nut facing the washer bottle) that way in the future if you have to remove your suspension for any reason, you wont have to touch the washer bottle.
Tip:
Tip:
Tip:
