You Zealand Super Stroke Up Kit ??
Old 12-31-10, 01:25 AM
ErickGS300
ErickGS300's Avatar
Default You Zealand Super Stroke Up Kit ??
Are there boys and girls driving with this You Zealand Super Stroke Up Kit on the 2GS??
Is this wurth the money??
This is a quick fix if you want to lower your car
without having to change the comfort of your
spring rate or stroke for the 92-05 Lexus GS
Features:
- Lower your front -25mm
- Lower you rear -25mm
Status: In Japan
Front $290
Rear $395
Old 12-31-10, 05:12 AM
Mr Jokster
Mr Jokster's Avatar
Isnt this just an RCA kit?
Old 12-31-10, 08:40 AM
99 GS3
99 GS3's Avatar
Sure looks like it.. It pretty purple tho
Old 12-31-10, 08:43 AM
97-SC300
97-SC300's Avatar
That's pretty expensive for two pieces of metal.... what's the stuff made of? Aerocraft lightweight aluminum or something?
Old 12-31-10, 08:54 AM
Frankdorn
Frankdorn's Avatar
$700 is a ripoff. I'd go with coilovers for not much more if your only intent is to lower.
Old 12-31-10, 09:00 AM
GSteg
GSteg's Avatar
Most likely it's the common 6061 aluminum. I can replicate the damn set for under $30 in parts, but because this one is purple (and labeled super stroke up), people are willing to pay $300 for the fronts. I need to get into the business of selling RCAs
Old 01-01-11, 11:55 AM
chrispy
chrispy's Avatar
I got a similar set that AutoFashion made for much less for the front and rear.
Old 01-01-11, 02:07 PM
SoloKaMGS
SoloKaMGS's Avatar
this crap is nonsense i wouldnt spend a penny on this , id get coils and change out bushing and be done. thats my personal .02
Old 01-01-11, 02:55 PM
sikkwidit
sikkwidit's Avatar
+1
Old 01-01-11, 11:32 PM
5t341th
5t341th's Avatar
this does other things as well.
clearance for LS calipers, more stroke in your shocks, etc
Old 01-02-11, 03:40 AM
PHML
Master Thread Closer!!
PHML's Avatar
SAGE and EXACT sells the same things....they are called RCAs in the states.....Super Stroke in jdm land.
SAGE's front RCA is 30mm = almost 1.2 inches drop (you need min 16 inch wheels)....while EXACT's is 38mm = almost 1.5 inches drop (you will need min 17 inch wheels).....both are priced at approx. $180 per set.
For a bit more more of a drop up front...SAGE has a limited run on 40mm front RCAs = almost 1.60 inch drop (also requires min 17 inch wheels).
Also, the SAGE and EXACT Rear kits are adjustable for camber correction....so you wont have to buy new tires every few months. The rears are priced about $300 per set.
YouZealand's is only 25mm all around = 0.98 inches....just shy of 1 inch drop.
Also, YouZealands Rear SS kit is NOT adjustable. Same goes for the AutoFashion set....it just drops your ride...WITHOUT any camber correction feature. No idea on the AutoFashion set, but they look like copies of the YouZealand kit.
Old 01-02-11, 05:13 AM
ErickGS300
ErickGS300's Avatar
This was the info i was waiting for.
Thanks guys.
Curated Content Editor
09-25-17 09:42 AM
I.B.dAt.Fo
09-14-07 11:56 AM
CamRen
12-09-04 09:37 PM
Styx
IS - 1st Gen (2001-2005)
07-29-04 06:03 PM
hnwg824
SC- 1st Gen (1992-2000)
09-05-03 08:40 PM
Quick Reply: You Zealand Super Stroke Up Kit ??
