Coilover Vs. Springs ?s
Hey CL, I have a ? i have been pondering for a while now. I am currently setting on Tein Stechs and have just under 1 finger gap all the way around. I just recently got a good deal on some BC Racing coils so I went ahead and bought them. My car is my DD and I am pretty happy with it setting the way it does. I drive moslty back roads to work and there are dips and bumps, with that being said, if i put the coils on is that going to give me a more harsh ride on my way to work? I want to keep my ride quality and and not really worried about being slammed. I really want this Vertex kit and would sell the coils to help fund the kit but if the coils will make my car actually ride much better then i will put them on. Please let me know what you experts think
Only one way to find out ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Not all BC coils come with the same spring rate. Some people get stiffer springs while others switched to softer. Anyone who says these will ride better than your current setup is jumping on the coil bandwagon because they don't know anything about your particular coils. If you're truly happy with what you got already, then just sell the BC coils, and maybe you might even make some money along the way. If you want the capability to adjust your height later on, then it's an incentive to switch the springs out.
Again, it really depends on the spring rate. BC has the option to go with springs that are quite stiffer than the off the shelf model. No one knows anything about the coils in question so it may or may not ride better than what he has now. The only option is to try them out. No amount of damping adjustment will make up for too stiff of a spring. Even having too soft of a spring can yield in a choppier ride if the damper forces are left alone. The adjustment should be be used for fine tuning, not compensating for the unmatched spring rate. I cringed when people turn their ***** closer to the extremes because it degrades the life of the shock
The s-tech springs are already soft as they are right now. He already likes the ride of it, but only he can determine how much more he can tolerate before it become unbearable. This is why I've always emphasize on getting a ride in someone else's car to get an impression of what it's like, rather than testing the waters with your own money.
Again, it really depends on the spring rate. BC has the option to go with springs that are quite stiffer than the off the shelf model. No one knows anything about the coils in question so it may or may not ride better than what he has now. The only option is to try them out. No amount of damping adjustment will make up for too stiff of a spring. Even having too soft of a spring can yield in a choppier ride if the damper forces are left alone. The adjustment should be be used for fine tuning, not compensating for the unmatched spring rate. I cringed when people turn their ***** closer to the extremes because it degrades the life of the shock ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
yea the ride along is a good idea actually. this way you can get an idea of how coils are and can make a better judgement.
Again it would depend on your coilovers. What spring rates do you have? I know people have option of selecting different spring rates prior to purchasing so not every coils will ride the same. If your spring rates are closer to 6-8kg/mm front and rear, then it'll be close, if not slightly stiffer than your Tein S-techs. If it comes with say 12kg/mm front and 8kg/mm rear, then you'll notice the difference when you drive over irregularities on the road.
