View Poll Results: what to you want?
I want endlinks
19
38.78%
I want tie rod ends.
30
61.22%
Voters: 49. You may not vote on this poll
FIGS Adjustable tie rod ends...renderings
#46
Excited about the front arms mentioned in another post and also about these:
As I've been really close to to ordering the Ikeya front arms and links a couple times, but would rather support a CL vendor if possible.. Oh and that this combo is $1480, hopefully the Figs would be considerably cheaper.
#47
should be much cheaper....and much lighter. I still think the Ikeya stuff is heavy for being race parts.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#48
OK, for some reason I was thinking of the other mount side. I see what they did there but man I bet that is a 1/4" plate. That adds a lot of weight into the system. The other advantage to mine is that I am using rod ends that are made to handle contamination and high misalignment. They should last a long time in this configuration. A set of machined plates may not be much cheaper especially if they are chromo. What is nightpager asking for the plates?
nightpager is asking about 150USD.
I may replace my tie rod ends soon since I am starting to feel some slack in the steering again. Depending on cost, I'll definitely be interested.
#52
just working out some details on the thread side of the stud, should be pretty soon. I place and order for the machined hex sections and the spacers as well as the front mount stud for the sway.
I will work on retail pricing.
__________________
#54
Yep I drive the F rain snow or shine.
__________________
#55
nice your finaly making these lcas i have been thinking this for two years now just dont have the time or machine shop to complete with these and the hi steer arms our front ends would be solid. cant wait great job figs
#57
getting built, 3 more weeks.
__________________
