BC Racing coilover adjustment
Old 07-04-11, 09:36 AM
swegs430
swegs430's Avatar
im on extreme drop aswell (BC) got the 12/10 and on like 15-17 clicks! still not hard and not soft! But i hate the travel in the whole suspension. Slaming the upper arm in the tower all the time! Is there a way to stiffen the complete "linkage" up to prevent the travel by the arms?
Old 07-04-11, 03:10 PM
GS4_Fiend
GS4_Fiend's Avatar
if you are slammed, it is necessary that you go FULL STIFF. If it still annoys you, either cut a hole for the UCA to travel or raise it up a tad.
Old 07-05-11, 01:31 AM
designo
designo's Avatar
Are there any heavy duty bump stops out there for cases like these?
Old 09-04-11, 03:03 AM
ErickGS300
ErickGS300's Avatar
Back from the graveyard.
I also having problems with my BC Racing 10k/8k on full stiff and almost a inch of preload. I haven't got the Extreme drop kit but riding my car pretty low so now i having trouble with the shocks. The fronts feel like there blown because when i drive over a small bump in the road at 30+ mph it feels like the shock is hitting the bottum of the damper. I ordered some 12k spring to put on the front and now i'm hoping to solve the problem of hitting the maximum of the damper.
Can any tell/predict me the result of a stiffer spring??
Does the extreme drop kit have a stiffer shock or is it just the springs??
This is how my 2GS stands:
Old 09-04-11, 11:58 AM
GS4_Fiend
GS4_Fiend's Avatar
I'm as low as you and I don't have any problems, 8k/6k. Are you sure it's not your UCA hitting? Mines hit when i go over bumps since mines a soft setup. Also, you got a 1 year warranty free replacement, you can contact BC.
Old 06-16-17, 06:56 PM
Maxtaa
Maxtaa's Avatar
I have an issue, i've been stupidly adjusting my height with the top collar. The car seems to have a bit too much travel, how do i go about resetting the preload to factory so i can adjust my height properly? My spring rates are F:10kg R:8kg
pwrusr
Suspension
01-05-16 08:52 PM
ATP
07-16-15 11:33 PM
zion14
Suspension and Brakes
09-04-14 09:57 PM
mdgrwl
26
11-19-11 05:17 PM
gs300cky
GS - 1st Gen (1993-1997)
12-07-09 11:11 AM
Quick Reply: BC Racing coilover adjustment
