Camber correction solutions. Front ? and Rear Mega Arms?
Old 01-10-11, 12:07 AM
istundra
istundra's Avatar
Question Camber correction solutions. Front ? and Rear Mega Arms?
Hi,
I have a GS300 lowered on stance coilovers about no finger gap all around. 18x8 oem 245/40/18.
I need to get my camber corrected...
I did some searching and found Figs mega arms can fix the rear and i was not certain what to use for the fronts.
At this time, i plan to replace the ball joints as well.... since i will be needing an alignment after the replacement.
TIA!
Old 01-10-11, 10:31 AM
sakataj
sakataj's Avatar
just a FYI,soon....figs is making a front control arm WITH camber adjustment just not out yet
Old 01-11-11, 11:13 AM
Infamous 1
Infamous 1's Avatar
Front RCA (SS kit). Relatively cheap and you can probably find a used set.
Old 01-11-11, 11:52 AM
GS4_Fiend
GS4_Fiend's Avatar
Originally Posted by istundra
Hi,
TIA!
Do you have problems with front or rear? I got the same setup as yours, just I got BC. I dont have any camber problems yet.
Old 01-12-11, 12:35 AM
Lextasy671
Lextasy671's Avatar
I just installed my Stance over the weekend with stock 16s...tucked tires...and i got bumpsteer...so sad =(...and gonna look into FIGs stuff.
Old 01-12-11, 03:40 PM
99 GS3
99 GS3's Avatar
Did you get any indication on how soon?
Hopefully by the end of February or so, the tax man owes me a nice chunk of change and my shopping list is growing..
Old 01-13-11, 12:34 AM
istundra
istundra's Avatar
on my old set.. i did... it was starting to get bald inside..
Toe for the front and rear shows green on the alignment print out.
Camber is in red and shows about -1.6 for the front and about -1.9 for the rears.
I just got some fresh tires so i do not want to see any camber wear yet.
Old 01-13-11, 09:02 AM
vwynn
vwynn's Avatar
theres also SPC UCA as well that has camber and caster adjustments.
dont forget about the JDM aftermarket arms. Theres prolly EVERY single aftermarket arm in japan thats wayyyy better than what we have here...
Old 01-13-11, 12:00 PM
GS4_Fiend
GS4_Fiend's Avatar
Green doesnt mean anything. What were the toe readings?
Old 01-15-11, 01:28 AM
istundra
istundra's Avatar
Previous Front total toe: 0.08 degrees
Front total toe: 0.18 degrees.
Previous Rear total toe: 0.16 degrees
Rear total toe : 0.12 degrees
Does it look any good?
Old 01-15-11, 10:35 AM
GS4_Fiend
GS4_Fiend's Avatar
Toe looks good. What about the thrust angle?
Old 01-15-11, 06:11 PM
istundra
istundra's Avatar
on the rear, the actual thrust angle is 0.00 degrees.
Thank you for helping looking over the spec sheet. i honestly dunno how to read it much. :P
esonu
Suspension
05-31-19 09:14 AM
darbs242
IS F (2008-2014)
04-03-13 07:52 PM
Lanceezy
Suspension and Brakes
12-02-12 11:26 PM
Iam99x
13
11-13-12 09:18 PM
NemeGuero
11-06-09 09:05 AM
Quick Reply: Camber correction solutions. Front ? and Rear Mega Arms?
