Coil Install Time?
Hey kybball this is out of the picture but how do you like your lc818 on your black is350?
I ordered mine but thinking if gunmetal would look better on the black is350 then the satin black give me your input since you have the same color car as me. Detailed if possible =D
Top is to lock in your pre load from BCR and the bottom is were you lock/unlock to turn the sleeve to get your ride height. But for me I just locked the bottom and used the upper locking bigger/smaller to adjust my height and still drove fine. But that just how I did mine. Most people use the lowwer one.
Make sure you adjust your settings and height the first time. If you don't have lifetime alignment, you will need to get alignments for each adjustments.
BCR Adjusting DIY
should take a shop about 2 hours to do the install since its pretty simple to swap out corners.
CircuitMS
Club Lexus Vendor Marketplace
12-02-13 10:21 AM
