Where to order hub bearing
The other day I spun out and hit a curb so bad that my stock wheels split and now its making a spinning-squeal sound which I'm almost sure is my hub bearing. Can somebody tell me where I can order this?
front driver side hub bearing if it makes a difference.
You can order from here.
http://is.sewellparts.com/#
If you register and put in that your from this forum, you get discount which a lot of us are registered on.
Tech Info Resource
BTW, you can't order the bearing, you'll have to order an entire hub. They don't sell the bearing separately, nor are there any instructions for disassembling and rebuilding the hubs. They are a remove and replace only item.
