help on bc coilovers
i noticed that its kinda weird adjusting the height on bc coilovers, shop i took it too had trouble they had seaid to me, they had to take the whole coilover out to preset the height why is that?
any help will do cuz im thinkin of lowering my car more n i dont wanna bother taking out the whole coilover set up
thanks in advance
thanks in advance
This is the proper way to do it.
Unloosen the bottom ring in blue, make sure the tops 2 rings in red are tighten up to one another, now put your spanner wrench on the very TOP RED ring and turn it counter clockwise to lower. If you need to raise you put your wrench on the bottom ring in RED and turn that clockwise to raise. Once you get your height set tighten down the lowest BLUE ring and your set.
This is HOW you do it.
Bud you have no idea what your talking about. Your not messing with preset since your not loosening the red collars, your using them as leverage to turn the threaded sleeve. Your handing out wrong info.
You didn't even install these so please allow someone with a mechanical background to give out CORRECT info.
You cannot turn the threads by hand while on the car without using a lot of energy and even then might take a while and still might not work.
The most basic way to describe it is this.
The shock is threaded like a giant bolt. The Lower mount is threaded like a Giant nut. So thread the bolt into the nut to raise or lower it. Thread the shock into the lower mount to lower it. Opposite to raise it.
VERY simple.
VERY simple.
