2007 IS350 - Brake Pads
Old 01-19-11 | 07:00 PM
ommar420's Avatar
ommar420
Post 2007 IS350 - Brake Pads
Need to change my brake pads on all 4 wheels on my IS350. My rotors look good and no need to be turned.
1. Can someone give me a complete instruction on how to change brake pads on all wheels on IS350?
2. Has someone used Duralast Gold Cmax/Brake Pads from autozone? Is it a dusting or non dusting pad?
I am thinking to go with Duralast pads. Right now I have the OEM non-dusting pads and hate it, and because it has low friction, I cant feel my brakes grabby anymore. Any suggestion on any other brand?
Old 01-19-11 | 07:18 PM
jbjones85's Avatar
jbjones85
There is a how to on the faq page
Old 01-19-11 | 08:26 PM
ecr527's Avatar
ecr527
Just to note, the DIY in the FAQ's actually says to remove the caliper when doing the rear pads, but I believe the OP just did that as he was also replacing his rotors. There is no need to remove any of the calipers if you're just replacing your pads. When you get the rear pads out, check to make sure that the caliper is not seized on the slide pin, otherwise you won't be able to get the new, thick pads in. Mine were, and the dealer was asking for $1100 to replace the calipers.
Old 01-20-11 | 09:10 AM
2IS350DT's Avatar
2IS350DT
yummmm
2011 IS350 AWD.. sexy!
Old 01-20-11 | 07:14 PM
ommar420's Avatar
ommar420
Default Is350 brake pad
Where can I find this DIY FAQ? I'm new into this thing! Tnx!!
Old 01-20-11 | 08:21 PM
windex's Avatar
windex
https://www.clublexus.com/forums/is-...tart-here.html
Here you go. welcome to the forums! check that thread next time you have a question before you make a thread... odds are that youll find the answer in there.
Old 01-25-11 | 11:32 PM
allst4r's Avatar
allst4r
for the og brake pads the dusty ones. do we need to bead in the new brakes?? ive read that the new dustless ones you dont need to bead in? somthing like it has coating on the outside and in 500 miles it will bead into your rotors with light every day usage???
any info would be great.
i just dont want to unnecessarily wear down my rotors beading in the new brakes.
Old 01-30-11 | 05:39 PM
HaveBlue's Avatar
HaveBlue
For $15 a rotor at the local shop, you should turn them. They may look ok but they likely aren't. I used ebc red stuff. Highly recommend those.
Old 01-30-11 | 08:54 PM
Kurtz's Avatar
Kurtz
Why?
Unless there's a significant visible lip, or otherwise something wrong with them (ie excessive uneven pad transfer- which would be noticeable when braking and the ignorant usually think is a 'warped' rotor) all turning them does is waste useful metal that could be used for stopping and shorten the life of the rotor.
Shervin350
Suspension and Brakes
24
03-08-12 05:19 PM
hybridanim
04-05-11 06:22 PM
JBasco20
02-26-10 08:28 AM
songkp012
01-24-09 12:03 AM
933005spd
SC- 1st Gen (1992-2000)
06-04-01 07:55 AM
