Pic Request - Megan LP / Megan EZ Street coilovers on 18/19 in wheels
This is mine in LP's and 19's. I could easily tuck rim on the lowest setting. the wheel gap will be gone when I get my LS400 bbk installed next week. With the dampening adjustability, you can have a factory ride while rolling slammed. For mr the softest setting is too soft and the stiffest setting is too stiff. Right now I have the set right about in the middle.
Registered User
My GS on LP's and 18's
Here is a pic of GS sitting pretty low on LP's and 18's (18x9 -10 and 18x10 -20) Ride is smooth but way to soft for my taste running this low, but I am going to be modifying mine.
Registered User
Thanks and no RCAs yet since I am still working on make my own that will give me the option for alittle more camber in the front to match the -11 degrees in the rear...
I am also working on afew other suspension mods for the front...
Havn't had a chance to snap a pic yet cuz we just got a ton of snow, but seeing these other pics of the LPs.... I don't think the EZ streets go as low.. at least mine don't. Dropped all the way without messin with the spring, theres still a slight gap between tire and fender on the front. The rears go really low though.
what's ur current tires setting?
[/QUOTE]
my setting is 225/35/19 in front and 245/40/19 in the rear. im debating should i go front bigger or the rear smaller to match.. cuz with the current setting.. it doesnt look good. check out the image below for my current setting. Will it fill the gap better if i lower it more in the front?
[/QUOTE]
Your tire setting are perfect i would probably drop down to a 35 series in the rear so you have the same side wall for front and rear, then just drop the car a little and you will be good. Thats a good tire Size. i wouldnt worry about that.
I just called Megan Racing and they confirmed the only major difference between these coilovers are
EZ
- 15 Levels of Adjustable Damper
- Aluminum Brackets paired with rubber inserts
LP
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
I was told that they have the same lowering capabilities.
EZ
LP
