Pic Request - Megan LP / Megan EZ Street coilovers on 18/19 in wheels
#76
thanks, and thanks to everyone who contributed info. Still looking on dampening feel reviews for ez
#79
I'm more than satisfied of the dampening of the EZs. Comparably.. My tein CS on full hard, felt about the same as the EZs a click or 2 from full soft. I have them set now in the middle at 8 and I think its just about right for my tastes... with 18's and TRD sway bar daily driven on some bumpy roads.
I am a bit skeptical of how low my EZs go in the front.. you said they should have the exact same height adjustability as the LPs... but my fronts would not tuck. The tire was just about flush with the fender when the lower perch bottomed out.
#81
Exact costs close to 500 for the front and back rca's
I believe sage is no longer being sold
#84
Here is the pic of my EZ's...
The fronts are 2 threads (~1/8 inch) from max drop. If you want them to go lower, the whole shock assembly is threaded, and the spring perch could be dropped another 4-5 inches. But I do not recommend adjusting the spring preload if you want proper damping. RCA's would be the way to go if you want it lower.
The rears were tucked when i first put them on.. here they have been raised ~1 inch from how they came.
#85
Finnaly papachulo with the save lol. I think ur the only one on all of CL that has the front almost lowered all the way on EZ's without messing with preload on CL with pix
thanks for the info man
#86
I went ahead and made an order for megan ez's. Some of the SC430 guys are saying they wonder why they spent the extra $ on the LPs when there isnt much difference aside from dampening adjustability.
Thanks guys hope this helps others, will be posting pics when mine arrive. Will be using sage rcas front and rear.
#87
#88
The ezs are on nationwide backorder so I wont have any pix till 3-4 weeks ish from now
hows the right height at right now silver? If its good and you like the ride then keep your setup. But for adjustability the ezs are a good deal for gettin from point A to B.
#89
Check out post #13 and I got a couple pics of my current ride height and set up. But, as I posted in that thread, since I got a new more aggressive set up, it almost forces me to switch to coilovers. I may try and test fit them with my current tire and suspension set up and see how they look. If it looks funny, and I need to tuck tires, then I'll switch it up
#90
I think your current suspension looks good for being springs, rcas help it a lot. rear needs to go down lower. I think you could benefit from coilovers.
Yeah just try out your new wheels + current suspension then figure out what u want to do from there gluck
