Best brakes
Old 01-28-11, 11:45 AM
BLKG3
BLKG3's Avatar
Default Best brakes
I know this is a question probably asked a million times over.
My brakes are due for replacement and would like to know what brand have had the best results among CL members. My GS300 is stock.
I am really considering going with OEM replacements; Since these are the brakes money is not an a problem. So I will go with what ever is best.
Any input is appreciated!
Thanks
Old 01-29-11, 12:13 AM
Scott1258
Scott1258's Avatar
Carbotech - the best pads you can buy. Go with the Carbotech Bobcat 1521 pads. Here's the link:
http://www.ctbrakes.com/brake-pads.asp
They will be a little noisy at first while they bed into your new rotors. But then they will be nice and quiet (5 to 10,000 miles give or take). Just call them up and order them. They take a couple weeks to get them as they make them to order generally.
I've had oem and akebono pro acts and these stop and feel way better than either of them. Not even close. They are considerably more $'s but IMO they are worth every cent. The GS is a heavy car and these pads work great with the weight we are pushing. I found the other two pads lacking greatly.
Old 01-29-11, 02:21 PM
Alexus_300
Alexus_300's Avatar
Pair some Stoptech Stainless Steel brake lines, ATE Blue brake fluid, and some Disc brake Australia 4000 series rotors with what Scott ^^ recommend above and you will have more than enough braking for any driving situation.
Old 01-30-11, 07:08 PM
LuxuryGS3
LuxuryGS3's Avatar
Holy s*** those Australia 4000 Rotors are super expensive.
Old 01-31-11, 01:15 AM
Scott1258
Scott1258's Avatar
Definately want SS brake lines - there are several folks that make these for our cars.
I have the LS400 front brake upgrade and it's tough finding rotors for this. I went with Centric rotors and got them through RockAuto.com and they were very inexpensive. Tirerack carries them too.
These have been rock solid rotors for me. I've had brembo blanks and these just rust like crazy. However, they were great rotors they just rusted. The Centrics have held up much better and have performed perfectly for me. Plus they are at a great price point. It costs more to have a rotor turned than it does to just buy a new Centric rotor and have it installed. They have paired up well with the CarboTech Bobcat pads. Recommended!
Old 02-01-11, 07:28 AM
AW99GS400
AW99GS400's Avatar
Ls400 calipers + stainless steel brake lines + cross drill and sloted rotor
+ ebc red pads works well for me
Old 02-01-11, 10:21 AM
vwynn
vwynn's Avatar
i want carbotech front TT pads and rear Gs pads .. so much money
Old 02-01-11, 10:23 AM
Is300Tree2
Is300Tree2's Avatar
Stock pads and get any aftermarket rotors.
Old 02-01-11, 11:34 AM
LuxuryGS3
LuxuryGS3's Avatar
Get these.. http://cgi.ebay.com/ebaymotors/Cross...Q5fAccessories
Plus.. Carbotech Pads + SS Brake Lines and you should be straight.
Old 02-01-11, 06:10 PM
Alexus_300
Alexus_300's Avatar
There not that really expensive. Around $175/rotor but will last you a long long time. I've used them on my GS300 for two season of track use before they wore out.
Old 02-01-11, 06:11 PM
Alexus_300
Alexus_300's Avatar
Gotta pay to play man. Good pads costs!
Alexus_300
Alexus_300's Avatar
I do not recommend those rotors since they are prone to crack and squeek!
Old 02-01-11, 06:14 PM
UpstateLex
UpstateLex's Avatar
what about bbk?
Old 02-01-11, 07:56 PM
kene
kene's Avatar
Just a question to you guys(just trying get an idea of what the GS members think on this)...
If considering BBK, would 800-900$ for a front set of ISF 14.2" rotors and corvette Zo-6 calipers, pads and special mounting bracket be considered overkill and too expensive in your eyes?
Old 02-02-11, 05:52 AM
LuxuryGS3
LuxuryGS3's Avatar
I did my research on Brakemotive and have heard nothing but good things about them on the GS forums, so I don't know. Just about everyone that has ever had rotors from them have said they had no problems whatsoever.
Quick Reply: Best brakes
