Camber experts please reply! (I'm NOT on coilovers)
I've got to admit, I'm pretty confused even after doing some research so I thought I would put this thread up since most of you guys have tackled the dreaded inner tire wear issue that is happening on the 2nd gen lowered GS.
I'm rolling on 20's and the inner tire wear on my front wheels is VERY bad.
What are my camber kit options if I am not on coilovers? Thanks CL.
Master Thread Closer!!
first off...what suspension are u running if not on coilovers? How much did u drop from stock height?
also, what does your alignment papers look like? Is both toe and camber out of spec?
Toe scrubs a tire diagonally across its tread because it is basically dragging the tire along the road. Camber causes inner (negative) or outer (positive) tire wear, so he definitely has a camber problem. Toe could play into it, but it isn't the most problematic wear angle in this case.
the GS doesnt have McPhersons up front, so coilovers arent going to help adjust camber cuz they wont have camber plates.
and ill state it again, my camber is at 6* and its not bad at all.
if ur tire wears very quick, it is from toe wear
98GS400GUY
Suspension and Brakes
03-24-10 10:05 PM
