sways r squeaking
has anyone noticed slight squeaking here and there after they installed their sways? maybe i tightened the bushings too much?? if anyone has had this problem or fixed it please tell me! thanks!!
T
T
I had that problem, My lexus tech just used lots of lube and it's fine now. BTW is your problem in the front or rear? also could you describe in more detail when the squeek is happening.
mrgs400 reported to us that speaking sways may indicate a broken link. the sways are held down by these little links or braces or whatever. but the sways are a lot stiffer than the stock ones so are prone to breaking the links, releasing one end and also causing the squeak.
or you just might need oil!
hey thanks for the replys guysd.. i JUST installed them so i dont think its the linkage.. i think i will just end up putting lots of lube like navaz recommended.. any kinda lube u recall??
i think the problem is the rear.. just kinda when i first take it out on the mornings.. im thinkin bushings r just kinda cold.. but we shall see after some lube.
T
T
vwynn
04-24-11 11:03 AM
