Broken Daizen Caster Bushin ?!?!?
Old 04-09-11, 02:35 PM
  #31
GSJake
GSJake's Avatar
Originally Posted by Kyle Harty
Was thinking after I posted, the TRD bushings would only fit the '03-'05 arms if I understand things correctly. Was there an upgrade in the bushings in '01 that would work for 98-00?
I think I might end up throwing in the ones from Carson and take my chances but if there's a better alternative it's not done yet.
Let us know what you end up with Kyle. I have an 04, so they are the TRD ones I guess. Were these poly or harder rubber?
Originally Posted by bADBOySC4
i personally test fitted both 98-99 and newer bushings. talk to Collin at Carson Toyota, Those bushings hold up a lot bettern than the daizen kit. the only bad part about them is that you have to reuse the inner sleeve (older style control arm) and the outer sleeve of the stock bushing (newer style). so you have to grind down the rubber off the stock sleeves. Not too bad of a job though. I was able to replace both sides in about 2 hours (and thats on a hoist at my dealer). Call Collin he'll hook u guys up.
bADBOy are you lowered at all, if so how much?
Old 04-09-11, 11:05 PM
  #32
bADBOySC4
bADBOySC4's Avatar
im sitting pretty low right now. not on air, im just slightly tucking the lips on my 19x9 and 19x10s right now. ive been riding that height for about a year on my bushings.
Old 06-02-11, 09:14 AM
  #33
bigjussin
bigjussin's Avatar
from the pictures on carson's site, they look just like the ast bushings i bought....which i cannot use as my tech didnt save the sleeves from the oe ones...so i'm trying to return them unless someone on here wants a pair for 85 shipped
Old 06-02-11, 03:28 PM
  #34
dungut
dungut's Avatar
I made the same mistake earlier this week on one arm. Did not realize it was too late, and mangled the outer sleeve and could not re-use. Luis at Carson Toyota was SUPER helpful when I called him frustrated and said I wanted to buy two new control arms. He suggested I find 1 used arm and go ahead with the poly bushing install. After several days of running around to find a used arm, I was able to get one and get the polys in. The handling difference is AMAZING. So if you can, find used arms and go with the polys. If you want new arms, I found them for 225 shipped brand new from ebay. Contact user: tombracco He is VERY helpful. Good Luck
Old 06-02-11, 04:33 PM
  #35
SlowGS4
SlowGS4's Avatar
I'm using the bushing from sewell now with no problems so far. I had daizens before and the outter sleeve was already removed, and so i just removed the daizens and now using the sewell bushings without the outter sleeve, you may want the metal tube that hold the bushing in place on the bolt though.
Old 06-06-11, 07:52 PM
  #36
bigjussin
bigjussin's Avatar
those are the bushings i have that i cannot use...will sell em for 75 shipped..new,unused
Old 06-10-11, 09:00 AM
  #37
flossabe
flossabe's Avatar
Possibility of tear propagation from a rough install or material failure, given the limited occurrences (6 still?), I would think 210's wouldn't lower it to the point of stressing it that much but they are a pretty tight bushing.
Old 06-13-11, 10:10 PM
  #38
samster
samster's Avatar
Originally Posted by wald.sc400
so far 5 of you guys have had this problem...any one else??... S#!t i just did my caster bushings when i installed my coilovers ...and to think of daizen's high reputation within the lexus community
yeah my bushing looks like that running on tein flex
Old 02-25-12, 12:51 PM
  #39
istundra
istundra's Avatar
bump for good pix on caster arm bushing #2 failure for lowered cars!
Old 03-29-12, 12:00 PM
  #40
justablkv8
justablkv8's Avatar
Apparently my caster is out on the pass side. Not 'out but just within spec'...caster is 8.0 deg
Only thing I can think of is the daizen bushings.
Now searching for something to replace it with.
Old 03-29-12, 12:35 PM
  #41
wald.sc400
BANNED for ripping off other members
wald.sc400's Avatar
you're within spec...not serious at all
SlowLife
05-25-16 08:37 PM
bentleymp2
Suspension and Brakes
01-08-16 09:28 AM
Tremander
11-01-15 12:09 PM
aarondds
10-06-10 03:47 AM
black sc
SC- 1st Gen (1992-2000)
12-25-01 06:52 PM
Quick Reply: Broken Daizen Caster Bushin ?!?!?
