Broken Daizen Caster Bushin ?!?!?
Old 02-17-11, 02:40 PM
bigjussin
bigjussin's Avatar
Default Broken Daizen Caster Bushin ?!?!?
was test fitting wheels to check for ls400 bbk fitment....noticed this wonderful sight...
Im wondering if its just a casting line that let go, or if its cracked all the way through....if it is, I'll be going back with Lexus bushings and filling them with some lower durometer urethane than the Daizens
Old 02-17-11, 02:56 PM
Rich350GT
Rich350GT's Avatar
is that control arm #2?
Old 02-17-11, 03:15 PM
bigjussin
bigjussin's Avatar
yes it is
tencharacters
Old 02-17-11, 03:33 PM
vwynn
vwynn's Avatar
prolly cuz of the angle of the arm when the car is slammed.
Old 02-26-11, 04:10 AM
bigjussin
bigjussin's Avatar
it's on nf210's...not exactly dumped
Old 03-02-11, 07:40 PM
tom steele
tom steele's Avatar
dont buy the ones from toyota parts zone i ordered them and they look really bad am going to send them back. i am going to try and order a jonny joint will see if it works. my daziens did the same thing and the shake is back.
Old 03-03-11, 09:15 AM
GSteg
GSteg's Avatar
One of the reasons why I got rid of my Daizen bushings... it just doesn't handle lowered cars that well. There is no degree of freedom in the vertical direction so when you're going down the road and your suspension is in motion, you're piercing the bushing's lip. I want to even say Daizen modeled the bushings for stock suspension. The OEM rubber bushings allows for more vertical deflection.
Old 03-03-11, 11:44 AM
excluesive
excluesive's Avatar
damn, this news is just coming out now? daizen doesn't work well with lowering, crap. I'm on air.
Old 03-03-11, 02:47 PM
GSteg
GSteg's Avatar
They're okay for very mild drops, but when you're slammed, they take a beating, especially around the lip area. Everyone go bug FIGS for his caster arms. They're the ones you want if you are slammed.
Old 03-03-11, 03:29 PM
excluesive
excluesive's Avatar
FIGS, I know you're reading this. Where at you at with those arms!
Old 03-03-11, 03:33 PM
epic1si
epic1si's Avatar
the lip area on my bushings sheared on one side when i installed hahaha still look like their holding and no shake though.
Old 03-03-11, 05:03 PM
lexusben
lexusben's Avatar
NF's provide the most modest drop out there and his broke. Would you guys recommend I get these, I have Eibach Springs. I don't feel like spending money on bushings that are going to break though.
Old 03-08-11, 10:00 AM
bigjussin
bigjussin's Avatar
unless some muppet jacked the car up on them
Old 03-08-11, 06:46 PM
the90zkid
the90zkid's Avatar
I have that same problem, and installed mine on nov/2010. It's now march/2011, and I have that problem. I'm looking for a new set of bushings that would actually do the job. I'm not stock sus, and the bushings are pretty worn. I took into considerations of the roads in ny, and ny weather. But i thought it could have lasted longer. Is there a better brand of buying?
Old 03-08-11, 07:45 PM
lexusben
lexusben's Avatar
Has anyone tried the Carson Camber Bushings? I'm guessing since they are about the same as the Daizen's they would end up doing the same thing?
Quick Reply: Broken Daizen Caster Bushin ?!?!?
