Anyone got a DIY Brake pads....
Old 08-20-02, 10:09 AM
futuregs
futuregs's Avatar
Default Anyone got a DIY Brake pads....
I'm gonna get some new EBC pads for the GS and change them myself. Was wondering how hard it is? If someone could get me a DIY I'd appreciate it alot. Thanks.
Old 08-20-02, 11:37 AM
Kbueno
Kbueno's Avatar
The brake pads are not easy to change but not super hard either. Biggest problem I had was installing the clips correctly on the fronts while getting them on the rotor before it all fell apart. The rears were pretty simple (tiny little things). The calipers are held on by (2) 17mm? bolts for each one. Just take off the bolts and slide the assembly off the rotor..make sure you compress the piston so the new pads will fit over the rotor when you re-install. I think someone put up a generic DIY for this job...I'll look for it or maybe someone knows where it is.
Hope that helps.
Peace
Old 08-20-02, 11:49 AM
DrewGS4
DrewGS4's Avatar
Future,
Check out this link.
http://www.mitsubishi-fto.org/workshop/front_discs/
Old 08-20-02, 01:12 PM
futuregs
futuregs's Avatar
Originally posted by DrewGS4
Future,
Is this link good for the GS???
Old 08-20-02, 02:01 PM
GS400_PUSHER
GS400_PUSHER's Avatar
its pretty much the same way! I've done mine twice and I can tell you its pretty easy to do. The hardest part is putting the pads on the rotor clips and hoping they don't pop out before you get them back on the rotor!
Old 08-20-02, 02:24 PM
DrewGS4
DrewGS4's Avatar
The link helps you as a guide, but is not GS specific. I would only do 1 at a time even take a digital snap shot of it so you know where all the parts go back. For beginners, all these clips and parts get to be confusing but its really not that complicated. If all else fails take it too your local brake shop.
Good luck
Old 08-20-02, 02:33 PM
futuregs
futuregs's Avatar
Good luck
LOL if all else fails, I wont be able to "STOP" at the brake shop.
Old 08-20-02, 02:40 PM
GS400_PUSHER
LOL ........ if you cant stop and wreck....I want to buy some parts off you ....Thats a j/k ok You should be fine just take your time!
Old 08-20-02, 02:54 PM
DrewGS4
DrewGS4's Avatar
LOL !!!
silkx3
Suspension and Brakes
03-06-16 07:05 PM
islexusred
10-10-12 09:07 AM
kryolla
03-14-10 10:33 PM
rrr
08-04-09 09:17 AM
lx470man
IS F (2008-2014)
03-12-09 06:26 PM
Quick Reply: Anyone got a DIY Brake pads....
